I wrote a PHP script to scrape the actual measurement values from the internal webpage of the weatherstation. I then create json messages in the Domoticz style for temperature, humidity, pressure, wind, lux etc. These are sent via MQTT to Domoticz.
The script is run once every 5 minutes using crontab, and the measurement values are updated.
I'm enclosing my code as an example.
<?php
// here we publish MQTT
// https://www.cloudmqtt.com/docs-php.html
// https://github.com/bluerhinos/phpMQTT
require("phpMQTT.php");
$mqtt = new phpMQTT("localhost", 1883, "ambient"); //Change client name to something unique
define ("PRODUCTION", "True");
// comment out to go to test mode
// array with sensor values for Domoticz.
// 0 means: do not send
$idxlookup = array (
'IndoorID' => 0,
'Outdoor1ID' => 0,
'inTemp' => 3,
'inHumi' => 5,
'AbsPress' => 0,
'RelPress' => 7,
'outTemp' => 4,
'outHumi' => 6,
'windir' => 0,
'avgwind' => 9,
'gustspeed' => 0,
'solarrad' => 0,
'uv' => 10,
'uvi' => 10,
'solarrad' => 11,
'rainofhourly' => 8,
'rainofdaily' => 0,
'rainofweekly' => 0,
'rainofmonthly' => 0,
'rainofyearly' => 0,
'CurrTime' => 0,
'inBattSta' => 0,
'outBattSta1' => 0,
'Apply' => 0,
'Cancel' => 0,
'rain_Default' => 0,
if (defined('PRODUCTION')) {
// create curl resource to retrieve the data from the weatherstation
$ch = curl_init();
// set url to the right page
curl_setopt($ch, CURLOPT_URL, "192.168.2.22/livedata.htm");
//return the transfer as a string
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
// $output contains the output string
$html = curl_exec($ch);
// close curl resource to free up system resources
curl_close($ch);
} else {
$html = file_get_contents('livedata.htm'); //get the html returned from the test page
$ambient_doc = new DOMDocument();
libxml_use_internal_errors(TRUE); //disable libxml errors
if(!empty($html)){ //if any html is actually returned
$ambient_doc->loadHTML($html);
libxml_clear_errors(); //remove errors for yucky html
$ambient_xpath = new DOMXPath($ambient_doc);
//get all the input fields which represent data from the weather station
// the name and the value are stored in attributes of the input field
// e.g:
// <td bgcolor="#EDEFEF"><div class="item_1">Indoor Temperature</div></td>
// <td bgcolor="#EDEFEF"><input name="inTemp" disabled="disabled" type="text" class="item_2" style="WIDTH: 80px" value="21.5" maxlength="5" /></td>
$ambient_row = $ambient_xpath->query('//input');
foreach ($ambient_row as $value) {
$attr = $value->getAttribute("name");
if ($attr) {
// store the name and the value for later processing
$ambient[$attr]['name'] = $attr;
$ambient[$attr]['value'] = $value->getAttribute("value");
$ambient[$attr]['idx'] = $idxlookup[$attr];
if ($mqtt->connect()) {
// now we have all values... go and create the JSON strings...
// note, string differs depending on kind of value... needs some work for Domoticz
// see: https://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s#Temperature
// Temperature
// json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEMP
//IDX = id of your device (This number can be found in the devices tab in the column "IDX")
//TEMP = Temperature
// indoor temperature
$arr = array ('idx' => $ambient['inTemp']['idx'], 'nvalue' => 0, 'svalue' => $ambient['inTemp']['value']);
// echo json_encode($arr) . "\n";
$mqtt->publish("domoticz/in",json_encode($arr),0);
// outdoor temperature
$arr = array ('idx' => $ambient['outTemp']['idx'], 'nvalue' => 0, 'svalue' => $ambient['outTemp']['value']);
// Humidity
//json.htm?type=command¶m=udevice&idx=IDX&nvalue=HUM&svalue=HUM_STAT
//The above sets the parameters for a Humidity device
//HUM = Humidity: 45%
//HUM_STAT = Humidity_status
//Humidity_status can be one of:
//0=Normal (30-70)
//1=Comfortable (50-60)
//2=Dry <30
//3=Wet >70
// indoor humidity
$val = $ambient['inHumi']['value'];
if ($val < 30) {
$s = 2;
} else if ($val > 70) {
$s = 3;
} else if (($val >= 50) && ($val <= 60)) {
$s = 1;
} else {
$s = 0;
// $arr = array ('idx' => $ambient['inHumi']['idx'], 'nvalue' => 'Humidity: ' . $val . '%', 'svalue' => $s);
$arr = array ('idx' => $ambient['inHumi']['idx'], 'nvalue' => (int)$val, 'svalue' => strval($s));
$val = $ambient['outHumi']['value'];
// outdoor humidity
if ($val < 30) {
$s = 2;
$s = 3;
$s = 1;
} else {
$s = 0;
// $arr = array ('idx' => $ambient['outHumi']['idx'], 'nvalue' => 'Humidity: ' . $val . '%', 'svalue' => $s);
$arr = array ('idx' => $ambient['outHumi']['idx'], 'nvalue' => (int)$val, 'svalue' => strval($s));
//Barometer
//json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=BAR;BAR_FOR
//The above sets the parameters for a Barometer device from hardware type 'General'
// BAR = Barometric pressure
// BAR_FOR = Barometer forecast
// Barometer forecast can be one of:
// 0 = Stable
// 1 = Sunny
// 2 = Cloudy
// 3 = Unstable
// 4 = Thunderstorm
// 5 = Unknown
// 6 = Cloudy/Rain
$arr = array ('idx' => $ambient['RelPress']['idx'], 'nvalue' => 0, 'svalue' => $ambient['RelPress']['value'] . ';5');
//Rain
//json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=RAINRATE;RAINCOUNTER
//RAINRATE = amount of rain in last hour
//RAINCOUNTER = continues counter of fallen Rain in mm
$arr = array ('idx' => $ambient['rainofhourly']['idx'], 'nvalue' => 0, 'svalue' => $ambient['rainofhourly']['value'] . ';' . $ambient['rainofyearly']['value']);
//Wind
//json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=WB;WD;WS;WG;22;24
//WB = Wind bearing (0-359)
//WD = Wind direction (S, SW, NNW, etc.)
//WS = 10 * Wind speed [m/s]
//WG = 10 * Gust [m/s]
//22 = Temperature
//24 = Temperature Windchill
// First build the datastring
$data = $ambient['windir']['value'];
$data = $data . ';' . degToCompass($ambient['windir']['value']);
$data = $data . ';' . $ambient['avgwind']['value'] * 10;
$data = $data . ';' . $ambient['gustspeed']['value'] * 10;
$data = $data . ';' . $ambient['outTemp']['value'];
// T_{\rm wc}=13.12 + 0.6215 T_{\rm a}-11.37 V^{+0.16} + 0.3965 T_{\rm a} V^{+0.16}\,\!
//where
//T_{\rm wc}\,\! is the wind chill index, based on the Celsius temperature scale,
//T_{\rm a}\,\! is the air temperature in degrees Celsius (°C), and
//V\,\! is the wind speed at 10 metres (standard anemometer height), in kilometres per hour (km/h).[9]
$v = $ambient['avgwind']['value'] * 3.6;
$twc = 13.12 + 0.6215 * $ambient['outTemp']['value'] - (11.37 * pow ($v, 0.16)) + (0.3965 * $ambient['outTemp']['value'] * pow ($v, 0.16));
$data = $data . ';' . $twc;
$arr = array ('idx' => $ambient['avgwind']['idx'], 'nvalue' => 0, 'svalue' => $data);
//UV
//json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=COUNTER;0
// COUNTER = Float (in example: 2.1) with current UV reading.
// Don't loose the ";0" at the end - without it database may corrupt.
$arr = array ('idx' => $ambient['uv']['idx'], 'nvalue' => 0, 'svalue' => $ambient['uvi']['value'] . ';0');
//Lux
//json.htm?type=command¶m=udevice&idx=IDX&svalue=VALUE
//VALUE = value of luminosity in Lux
$arr = array ('idx' => $ambient['solarrad']['idx'], 'svalue' => $ambient['solarrad']['value']);
$mqtt->close();
} else {
echo "No MQTT connection";
function degToCompass($num) {
// from a degree value on the compass rose, create the textual representation
if ($num < 0) $num += 360;
if ($num >= 360) $num -= 360;
$val = round (($num-11.25) / 22.5); // each segment is 22.5 degrees... place the number in the middle
$arr = array ("N","NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","NNW");
return $arr[abs($val)]; // use absolute values to ensure that 359 degrees translates as N, like 1 degree
Peter
