More than 1, 1 channel 433 mhz devices? Topic is solved
BarryT
Domoticz version: 2024.3
Post by BarryT »
Hi!
I was wondering, is it possible to have (for example) 5 of the same devices wich have only 1 channel?
What i'm trying to ask is, cheap (temp/pir/switch) sensors wich have 1 channel to send/recieve.
Are they all talking all to the same device in domoticz then, or can i use them stand alone and do they dont interrupt each other?
Can't find the answer on the forum... :roll:
SweetPants
Re: More than 1, 1 channel 433 mhz devices?
Post by SweetPants »
I don't understand what you mean. 433Mhz devices use only one frequency and depending on the protocol/address/id used you can have multiple devices of the same type.
BarryT
Post by BarryT »
Okay! That was my question indeed...
Will try that later on, thanks!
