I have tried it but no minutes are displayed, i started pinball locallyErwinvos72 wrote:Thnx for the nice script but i have 2 questions
- when i create a system alive checker i only see the xbox 360 'on' when i do a internet test. After the test the xbox goes back to off and the xbox is still on. Do you know why?
- I created the timer but nothing was recorded. I created the script with atom editor on a windows pc and after that i did a conversion to linux to get rid of dos endings etc. Now i added the line 'commandArray['UpdateDevice'] = timer_device_ID .. '|0|' .. tostring(TotalMinutesOn)' directly under 'commandArray = {}' and will try it 2night. But could i have made a mistake by do it on windows and convert it afterwards?
Playstation timer
Erwinvos72
Re: Playstation timer
mvzut
Don't know if the PS4 has an API which supports this, I could at least not find it in a quick Google search. You could perhaps also (temporarily) block internet access of the PS4 via the router. That would also render it useless in most cases (at least for my son, who is almost always playing online). But it probably isn't easy or even possible to perform a device block via an API call to your router or something. Although my (ASUS) router should somehow support external configuration, since I can block access to any device using an ASUS app on my iPhone.Derik wrote:Should there be not a option to shutdown a PS with a api or something else?
The power socket solution will not work for my kids...[ there smart like there mom..]
mvzut
Playstation timer
Apparently the XBOX 360 does not respond to pings all the time, no idea why. You can do an extra check by simply typing "ping <ip address xbox>" in a command line (windows or linux). Check the reaction: if it's a few lines with times (in ms) it should also work with the ping plug-in. If it gives a timeout, there's not much we can do, except when this behaviour can be configured somewhere in the network settings screen (but I doubt it).Erwinvos72 wrote:Thnx for the nice script but i have 2 questions
Erwinvos72
I have gone through the process again and i think i saw some 'dumb' failures from my side. First off all, i have no Playstation, but a Xbox. With that said, i created a XBox timer and a Xbox device in hardware. But i never change those values to the script. There still stood Playstation timer and playstation 4 instead of Xbox timer and xbox.
I changed it and will check ik again 2night. I also created 2 additional timers to check if it works, one for the tv and one for my ipad.
Erwinvos72
I managed to get it workingErwinvos72 wrote:I have gone through the process again and i think i saw some 'dumb' failures from my side. First off all, i have no Playstation, but a Xbox. With that said, i created a XBox timer and a Xbox device in hardware. But i never change those values to the script. There still stood Playstation timer and playstation 4 instead of Xbox timer and xbox.
mvzut
Good to hear!Erwinvos72 wrote:I managed to get it working.
I had problems with it today myself. The Playstation suddenly changed its IP address after a router firmware update, but after updating the addres in the ping plugin, I could somehow not read the status of the device in Domoticz (lua) anymore?! I then deleted the decive completely and recreated it. Now it works again. I thought I'd share my experience in case others are ever dealing with the same issue.
safi78
- Domoticz version: LastBeta
@mvzut: afaik the 'pinger' in domoticz is buggy and unreliable. That could explain some of the posts above (it pings devices when they are not there, or says it's gone when it's not, first hand experience). I don't know if the 'pinger' is fixed yet. Till then I use this script: viewtopic.php?f=6&t=10742
@Erwinvos72: afaik an Xbox doesn't respond to ping & cannot be told to. I wasted a lot of time on that
But if you managed to get it working, I'm really curious how!
cheers.
cheers.
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
Erwinvos72
@safi78, thnx for your reply. I indeed noticed that the xbox isn't responding to ping. So that part i let go. I thought to change the lua script to assign the tv to the xbox script instead of the xbox but then i get wrong information, because the tv is pinging but that doesn't mean that the xbox is on.
safi78
@Erwin: I had somewhat of a brainfart
You can also use 'arping' on Linux, pings devices on a low level (has to be done as root).
I update the meantioned script (replaced the 'ping'-command with 'sudo arping' they take the same arguments, so works instantly). Either sudo without password or run the script as root of course ....
This pings my otherwise unpingable devices as well (a windows laptop, apple tv4, xbox to be tested, but pretty sure that's gonna work as well .. )
Maybe you can use it
Martijn85
- Domoticz version: Stable
Works great! Thanks for sharing
safi78
no problemMartijn85 wrote:Works great! Thanks for sharing
franzelare
thanks for the script!
nice work, i have been thinking about it but did not build it yet.. so based my code on your script and pimped it a bit with a table for multiple devices.
might be of use for other people who want to track more devices for the ontime.
you can just add devices and increase the device count to the number of devices you have added, the script here is now for 2 devices
I run this in combination with a arp scan on the devices in my network since that works better for me than a ping
-- device ontimer script rev 1.0 by franzelare
-- this script is to detect on time of devices in domoticz
-- based on the script of mvzut that can be found here on the forum
-- https://www.domoticz.com/forum/viewtopic.php?f=38&t=11985&sid=19cb4cb949d30eb8f27a797f598ad2f1
-- this has to be a time based lua script in domoticz (as device script this will not work
-- for every device to monitor a counter has to be created as virtual devicecount
-- Create an incremental counter using the Dummy hardware component (first add this component if you haven't already done so before, using Setup>Hardware).
-- Then go to the Utility section, change the type of your new counter from Energy to Counter, and fill in the Value Quantity (e.g. "On time") and Value Units ("Minutes").
-- Check the Device ID (idx) that is given to the new counter device.
-- this script can be run in combination with an ping, bluetooth scan or an arp scan what is in some cases more reliable
-- ping: https://www.domoticz.com/wiki/Presence_detection
-- bluetooth: https://www.domoticz.com/wiki/Presence_detection_(Bluetooth_4.0_Low_energy_Beacon)
-- arp scan: https://www.domoticz.com/forum/viewtopic.php?f=23&t=5256
-- define general script values
devicecount = 2 -- number of deviced to be cheked by the script for on time
PRINT_MODE = true -- when true wil print output to log and send notifications
-- create a table to store device information
devicetable = {}
-- Device 1
device = 1
devicetable["name" .. device] = 'FransMobiel' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'FransMobielTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 237 -- idx of the counter created for this device
-- Device 2
device=2
devicetable["name" .. device] = 'SusanMobiel' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SusanMobielTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 238 -- idx of the counter created for this device
for i=1,devicecount do
if otherdevices[devicetable["name" .. i]] == 'On' then
TotalMinutesOn = otherdevices_svalues[devicetable["timer" .. i]]
TotalMinutesOnNew = TotalMinutesOn + 1
commandArray['UpdateDevice'] = devicetable["ID" .. i] .. '|0|' .. tostring(TotalMinutesOnNew)
if PRINT_MODE == true then
print('Device sequence: ' .. i)
print('Device detected On :' .. devicetable["name" .. i])
print('Previous on time: ' .. TotalMinutesOn)
print('New on time: ' .. TotalMinutesOnNew)
elseif otherdevices[devicetable["name" .. i]] == 'Off' then
print('Device detected Off: ' .. devicetable["name" .. i])
print('No update of the timer needed')
print('Device ERROR: ' .. devicetable["name" .. i])
sdsi
Hi,franzelare wrote: nice work, i have been thinking about it but did not build it yet.. so based my code on your script and pimped it a bit with a table for multiple devices.
Just testing it - it only counts the last device; so, when I set "devicecount = 2' it counts second device, not first. when I set "devicecount = 1" - it counts first device.
Try it and please let me know the fix
Thanks.
franzelare
yes I also noticed later and fixed it...sdsi wrote:Hi,franzelare wrote: nice work, i have been thinking about it but did not build it yet.. so based my code on your script and pimped it a bit with a table for multiple devices.
Thanks.
devicecount = 11 -- number of deviced to be cheked by the script for on time
PRINT_MODE = false -- when true wil print output to log and send notifications
devicetable = {}
-- Device 1
device = 1
-- Device 2
device=2
-- Device 3
device=3
devicetable["name" .. device] = 'FransTablet' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'FransTabletTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 239 -- idx of the counter created for this device
-- Device 4
device=4
devicetable["name" .. device] = 'SusanTablet' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SusanTabletTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 240 -- idx of the counter created for this device
-- Device 5
device=5
devicetable["name" .. device] = 'FransPC' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'FransPCTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 241 -- idx of the counter created for this device
-- Device 6
device=6
devicetable["name" .. device] = 'SusanPC' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SusanPCTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 242 -- idx of the counter created for this device
-- Device 7
device=7
devicetable["name" .. device] = 'SonyBlueRay' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SonyBlueRayTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 243 -- idx of the counter created for this device
-- Device 8
device=8
devicetable["name" .. device] = 'ITV receiver' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ITV receiverTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 244 -- idx of the counter created for this device
-- Device 9
device=9
devicetable["name" .. device] = 'ASM-Lan' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ASM-LanTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 245 -- idx of the counter created for this device
-- Device 10
device=10
devicetable["name" .. device] = 'ASM-Wifi' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ASM-WifiTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 246 -- idx of the counter created for this device
-- Device 11
device=11
devicetable["name" .. device] = 'Chromecast' -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ChromecastTimer' -- exact name of the counter created for this device
devicetable["ID" .. device] = 247 -- idx of the counter created for this device
TimerID = devicetable["ID" .. i]
print('Device name detected On :' .. devicetable["name" .. i])
print('Device name On timer :' .. devicetable["timer" .. i])
print('Device ID timer counter :' .. TimerID)
print('Timer value: ' .. otherdevices_svalues[devicetable["timer" .. i]])
TotalMinutesOnRaw = (otherdevices_svalues[devicetable["timer" .. i]])
Part=1
for match in (TotalMinutesOnRaw..';'):gmatch("(.-)"..';') do
if Part==1 then TotalMinutesOn = tonumber(match) end
Part=Part+1
execcommandOn="sudo /home/pi/domoticz/scripts/bash/SetCounter.sh "..TimerID.." "..TotalMinutesOnNew.." &"
os.execute(execcommandOn)
return commandArrayCode: Select all
#!/bin/bash
IDX=$1
COUNT=$2
curl "http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=$IDX&nvalue=0&svalue=$COUNT"-
mvzut
Playstation timer
Just curious, but why have you changed from LUA UpdateDevice commands to json calls? And if you decided to use json, why do you use a bash script for them? You can also do that directly from LUA using e.g.franzelare wrote: and using a bash scripts to set the counters through json:Code: Select all
#!/bin/bash IDX=$1 COUNT=$2 curl "http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=$IDX&nvalue=0&svalue=$COUNT"
http = require "socket.http"
http.request('http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx='..IDX..'&nvalue=0&svalue='..COUNT)Raspberry Pi 4 - RFXtrx433 - CC2531 Zigbee - Opentherm Gateway - P1 smart meter - Netatmo - Philips Hue - ELV Max! - ESP8266 DIY water meter - 6 x Sonos - 4 x IP cameras - Wall mounted tablet + Dashticz - Google Home integration - MANY switches/sensors
franzelare
the LUA UpdateDevice commands only works for one device as you noticed... so had to change it.
I cound have called the json comment from the LUA script... but didn't think about that and the bash script was about ready from an other project.
I don't have time outs on the script, did have them before on other scripts but only due to other scripts that were called out to were wrong (like python or bash scripts)
corederoma82
I'm sorry but I don't understand.
I have domoticz installed on Windows, can I create a LUA script with name like "script_time_playstation_update.lua" and pit it in the LUA directory?
Then? To execut the script???
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
corederoma82
Counter is not functioning for me.....
CaesarPL
Scripts starting with _time_ are part of internal Domoticz routine and are run automaticallycorederoma82 wrote: Thursday 18 January 2018 9:44 I'm sorry but I don't understand.
corederoma82
Thanks, problem solved.CaesarPL wrote: Sunday 21 January 2018 10:03
