I'm using JABLOTRON TP-98TX Thermostat for floor heating at home. These are running 433,92Mhz to transmit data to the receiver when heating shall be triggered ON or OFF. basically, it measures the room temperature, and if the temperature is 0,5 degrees above the value that is set, then it will signal to the receiver to stop heating, and if the temperature is 0,5 degrees below the set value, then it will signal to the receiver to start heating.
I would like to get the signal from the thermostat, and monitor it on Domotics, in this what I can graph the room temperature changes.
The problem is that the 433,92Mhz is signal is not seen at all by the RFXcom at all.
Anyone knows anything about that?
Thanks.
