How to create rules in Domoticz Web UI Topic is solved
antares
Post by antares »
though I'm new to the area of home automation, I am amazed what a great work has been done by the community. I managed to install Domoticz on a Raspberry Pi and to add some Z-Wave devices like temperature and motion sensors and wall plugs, and Danfoss living connect. So far so good...
Now, unfortunately, I haven't yet managed in Domoticz to figure out how I can configure some rule like "if the room temperature is below 22 degrees, turn on heating" or "if door is opened and it is dark (light sensor), turn on the lights". I tried to play around with scenes, but I was not able to get other stuff created like "at sunset turn on the lights". Unfortunately, I was also not able to find out more by searching the forum or Google (provided, I might not have used the right keywords and missed it).
Could somebody please help me to figure out, how I can create rules like the above using the Domoticz web UI, such that the home gets really "smart"?
Thanks a lot in advance!
Egregius
Domoticz version: v2024.7
Re: How to create rules in Domoticz Web UI
Post by Egregius »
Start with blockly for simple things.
Continue with scripts in lua, shell, php etc for advanced stuff.
antares
Post by antares »
Hi!
Thanks. I read about it, but I didn't find yet where to configure it... aaaah -- it's not under the "main" menu but under the settings -> more settings. I didn't see that.
Are those event rules directly activated then or do I need to activate them from somewhere else as well?
Thanks a lot! I feel like I was blind.
emme
Domoticz version: latest
Post by emme »
you can shoose between different method:
ALL - the script/blocky runs and at the end restarts immediately
DEVICE - the script runs when ANY configured device changes its state. Your script should handle the device needed
SECURITY - script is activated when a security device changes its state
TIME - runs once a minute
"We always done this way"
rowanbradley
Domoticz version: 3.9025
Post by rowanbradley »
I don't understand this. As far as I can see, Domoticz doesn't have a Settings menu. It has Setup, but under Setup there is no More Settings (or More Setup) sub-menu. Can someone please explain to me how I set things up to take a temperature measurement every 5 minutes?
Thank you - Rowan
snellejellep
Post by snellejellep »
maby this screenshot can help you?
Egregius
Post by Egregius »
In English: Setup -> More Options -> Events
blauwebuis
Domoticz version: current
Post by blauwebuis »
If you install the Aurora theme you gain the ability to import and export your blockly's
cogliostrio
Post by cogliostrio »
Have a look in the wiki. It has a very good entry on blockly.
https://www.domoticz.com/wiki/Blockly
