I have recently moved to using Rfxcom.
Can someone in this group please suggest a Motion Sensor that works well with Rfxcom (from within domoticz) ?
Also looking for Smoke, Flood, Door and PowerMeter-SmartPlug that works well with Rfxcom.
Your suggestions will be most appreciated.
thanks.
Rfxcom - Motion Sensor? Topic is solved
DanM
Re: Rfxcom - Motion Sensor?
Give the Marmitek X10 Motion Detector a go. You should also be aware that some motion sensors that are RFXcom compatible can block other signals - this one doesnt. Ive had 2 of these working well with domoticz for years.
kman
Thanks DanM
- emme
- Domoticz version: latest
I had a chuango GSM Alarm system but the controlled dead, so I recycled the devices: PIR, flood and gas leak sensor...
they works pretty good... just a PIR has some problems but I thonk it is broken...
"We always done this way"
- bbqkees
- Domoticz version: 4.1x
Yes, get the X10 MS13 sensors. They may be sold under the Marmitek brand but also non-branded.
They work very well and batteries last for over a year here.
