Egregius wrote:Marked as dead has nothing to do with the flashing led, except that it starts flashing after x minutes of no communications.
You should figure out why it gets marked as dead, maybe something is causing interference.
Try moving the greenwave or the zwave antenna.
Correct, that's why I don't want it to be declared dead
It just notifies me of the latest issue.
Interference is possible although the distance is only a few meters. It also happened when the distance to the controller was only 1,5 meter of less.
And it happens completely random, from twice a day to no issues for many weeks. The log only mentions 3 timeouts and then declares the greenwave dead. No other indications for problems or causes. There are two other mains sockets in the neighbourhood, so some communication should be possible.
What I am looking for is that I can send the same command to the greenwave after some timeouts, as the Pi/Domoticz/controller sends when rebooting the system. Then I have a software workaround. The greenwave always listens, I do not have to touch it to get it alive again.
