homebridge-edomoticz Plugin
simon_rb
Re: homebridge-edomoticz Plugin
Post by simon_rb »
deejc wrote:Lol Image this thread makes me laugh
Toyman
Post by Toyman »
deejc wrote:all working!!
nice one, as usual 8-)
How is your "telly" listed in Domoticz? As a selector switch?
After looking at your screenshot, I've created a dummy selector switch but it doesn't appear in Eve at all
deejc
Domoticz version: 3.5641
Post by deejc »
I'm using the homebridge-Panasonic plugin but it's not that great , can't change channel with it, I can turn it on and off tho, I also get the same functionality using the Panasonic hardware within domoticz so wondering if @marci could implement it in this plugin with the Json output and enable channel changing etc
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
Toyman
Post by Toyman »
deejc wrote:I'm using the homebridge-Panasonic plugin but it's not that great , can't change channel with it, I can turn it on and off tho, I also get the same functionality using the Panasonic hardware within domoticz so wondering if @marci could implement it in this plugin with the Json output and enable channel changing etc
Got it, thx
Marci
Domoticz version: 3.8153
Post by Marci »
Throw up the json for it and I'll take a look...
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
deejc
Post by deejc »
Marci wrote:Throw up the json for it and I'll take a look...
Yeah I thought that was the case but I haven't managed to get to it yet, not sure how channels could be done in homebridge if at all, the current panny plugin has a 1-100 slider which is ussless and Siri doesn't seem to understand change "channel" or "telly" or even "tv" even after renaming the service.
Marci
Post by Marci »
Siri won't - custom characteristics and service types don't get Siri interaction.
deejc
Post by deejc »
shame, that would be pretty good.
not really worth doing the work on it then mate as i can turn it on and off now, using the built in switch or the panny plugin.
deejc
Post by deejc »
Does anyone use an External PIR ?
im looking for something reasnably reliable to use out side in the garden, i have z-wave and RFXCom receiver
tcviper
Post by tcviper »
Maybe a stupid question, but edomoticz/homebridge is working fine for me except P1 energy and gas, homekit says Not supported while in your first post it says you support energy metering? This is a p1 cable connected from RPI2 to P1 port (energy/gas meter). In domoticz it is working fine and showing gas and energy.
Toyman
Post by Toyman »
tcviper wrote:Maybe a stupid question, but edomoticz/homebridge is working fine for me except P1 energy and gas, homekit says Not supported while in your first post it says you support energy metering? This is a p1 cable connected from RPI2 to P1 port (energy/gas meter). In domoticz it is working fine and showing gas and energy.
What app do you use? New Home app indeed shows the meters as unsupported, but Elgato Eve should show them correctly
Marci
Post by Marci »
Specificity.
HomeKit = a protocol. Been around for several years.
Home app = Apple native HomeKit Client in iOS10, BETA. Only recognises Apple pre-defined characteristics. Been around in unfinished state for several months.
Home.app = Independant HomeKit Client for iOS8+ in the App Store, recognises custom characteristics but doesn't allow direct control. Been around for several years.
Eve = Independant HomeKit Client for iOS8+ in the App Store, recognises custom characteristics, allows direct control. Been around for several years.
Home app, an unfinished beta product for an unfinished beta Operating System, says something isn't supported.
All other HomeKit clients WHICH SUPPORT CUSTOM CHARACTERISTICS fully recognise and work fine as intended.
TLDR: don't bother asking me to fix things for a product that isn't finished/released.
Last edited by Marci on Saturday 10 September 2016 13:00, edited 2 times in total.
simon_rb
Post by simon_rb »
Marci, how's the MQTT final release coming along?
Marci
Post by Marci »
deejc wrote:Does anyone use an External PIR ?
Cheap IR module hooked up to 1-wire DS18b20 on RaspPi GPIO is how I do it... when PIR detects motion it sends power to the temp sensor. Therefore when temp sensor reads anything other than 0, there is movement... but I have a ring of cat5 going round the house and garden so I can splice sensors onto the 1-wire network wherever / whenever. 100% reliable.
Not experimented with any wire-free solutions as of yet, but when I do it'll be a Pi Mini with wifi dongle and the above, running from battery, with slave Domoticz, transmitting signal via MQTT back to master Domoticz - should cost about £15 in bits all-in, with each mini providing full compliment of gpio pins at each remote location. Ultimate expandability!
Last edited by Marci on Saturday 10 September 2016 13:07, edited 4 times in total.
simon_rb
Post by simon_rb »
Did you find anything?
I'd be interested in this too. I have seen cheap Chinese things on eBay which will send a 433mhz command when it detects movement but won't send a command once the movement has stopped. I think they will work in domoticz.
Marci
Post by Marci »
simon_rb wrote:Marci, how's the MQTT final release coming along?
Will be working on it this afternoon. All down to disparity between domoticz http JSON & MQTT svalues depending on meter types and subtypes + outstanding GitHub issues tagged 'bug'. Once they're nailed, good to go (other than suitable simple documentation to get folks up and running with a broker).
simon_rb
Post by simon_rb »
Excellent.. looking forward to it. Appreciate all your hard work.
deejc
Post by deejc »
I got a homeeasy one from the uk automation website they do an ext one which can be set to restart motion after 5 seconds and I set the off time in Domo to 5 seconds
simon_rb
Post by simon_rb »
Do they still sell homeeasy stuff? Most of my light switches and sockets are homeeasy but I thought they stopped a long time ago
Marci
Post by Marci »
(As I work as data analyst & WebDev at a U.K. SixthFormCollege, we're at the annual month-of-hell sorting census, funding & enrolment etc, so am limited to Saturday afternoons for doing any serious work on hB-eD, which has slown the pace a tad.)
