deejc wrote:Lol this thread makes me laugh
How is your "telly" listed in Domoticz? As a selector switch?deejc wrote:all working!!
nice one, as usual
Got it, thxdeejc wrote:I'm using the homebridge-Panasonic plugin but it's not that great , can't change channel with it, I can turn it on and off tho, I also get the same functionality using the Panasonic hardware within domoticz so wondering if @marci could implement it in this plugin with the Json output and enable channel changing etc
Yeah I thought that was the case but I haven't managed to get to it yet, not sure how channels could be done in homebridge if at all, the current panny plugin has a 1-100 slider which is ussless and Siri doesn't seem to understand change "channel" or "telly" or even "tv" even after renaming the service.Marci wrote:Throw up the json for it and I'll take a look...
What app do you use? New Home app indeed shows the meters as unsupported, but Elgato Eve should show them correctlytcviper wrote:Maybe a stupid question, but edomoticz/homebridge is working fine for me except P1 energy and gas, homekit says Not supported while in your first post it says you support energy metering? This is a p1 cable connected from RPI2 to P1 port (energy/gas meter). In domoticz it is working fine and showing gas and energy.
Cheap IR module hooked up to 1-wire DS18b20 on RaspPi GPIO is how I do it... when PIR detects motion it sends power to the temp sensor. Therefore when temp sensor reads anything other than 0, there is movement... but I have a ring of cat5 going round the house and garden so I can splice sensors onto the 1-wire network wherever / whenever. 100% reliable.deejc wrote:Does anyone use an External PIR ?
im looking for something reasnably reliable to use out side in the garden, i have z-wave and RFXCom receiver
Did you find anything?deejc wrote:Does anyone use an External PIR ?
Will be working on it this afternoon. All down to disparity between domoticz http JSON & MQTT svalues depending on meter types and subtypes + outstanding GitHub issues tagged 'bug'. Once they're nailed, good to go (other than suitable simple documentation to get folks up and running with a broker).simon_rb wrote:Marci, how's the MQTT final release coming along?
I got a homeeasy one from the uk automation website they do an ext one which can be set to restart motion after 5 seconds and I set the off time in Domo to 5 secondssimon_rb wrote:Did you find anything?deejc wrote:Does anyone use an External PIR ?
I'd be interested in this too. I have seen cheap Chinese things on eBay which will send a 433mhz command when it detects movement but won't send a command once the movement has stopped. I think they will work in domoticz.
