Cheap chinese z-wave products
Re: Cheap chinese z-wave products
So are you guys talking about a power plug or motion sensor? As the link is to motion sensor while the text sounds like a wall plug:-)
found the motion sensor on regular aliexpress for some 38 USD which is not bad compared to fibaro...
Derik
- Domoticz version: BETA
Nope Just lux [ by me ]splitfile wrote:Can it measure the temperature as well? (Like the Fibaro motion sensor can)Derik wrote:mmm Think this cheaper then in Holland:
https://nl.aliexpress.com/item/NEO-COOL ... rue#extend
Work great 1 @ home.
2 days so...
Goldwing1973
- Domoticz version: Stable
We were talking about a motion sensor, but LouiS22 mixed it up with a Power Plug.tequila wrote:So are you guys talking about a power plug or motion sensor? As the link is to motion sensor while the text sounds like a wall plug:-)
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
I see, so both motion sensor and power plug are working fine with Domoticz?
Goldwing1973
Power Plug, yes (own experience)tequila wrote:I see, so both motion sensor and power plug are working fine with Domoticz?
Motion Sensor, I have ordered one, but didn't receive it yet, so i can't tell from my own experience, but others are saying it's working fine.
Re: RE: Re: Cheap chinese z-wave products
thanks buddy!Goldwing1973 wrote:Power Plug, yes (own experience)tequila wrote:I see, so both motion sensor and power plug are working fine with Domoticz?
- LouiS22
My bad, sorryGoldwing1973 wrote:We were talking about a motion sensor, but LouiS22 mixed it up with a Power Plug.tequila wrote:So are you guys talking about a power plug or motion sensor? As the link is to motion sensor while the text sounds like a wall plug:-)
- LouiS22
My door sensor finally arrived - and it's working. The overall quality is good.
My Neo Cool Cam motion sensor also arrived, and it's also working good.
Quality looks and feels good
Verstuurd vanaf mijn SM-G935F met Tapatalk
nmaster
- Domoticz version: 3.6304
Is these sensors are zwave+ or only zwave ?
Because I only have zwave+ network now and I don't want to add zwave only devices to it.
Thanks.
Thanks.
Goldwing1973
The Power Plug from Neo is z-wave+, the Motion Sensor from Neo is z-wave+ and the Door/Window Sensor is also z-wave+nmaster wrote:Hi,
Thanks.
Don't know about other devices from Neo.
nmaster
Thanks Goldwing1973.
I'm interested by the power plug and the flood sensor.
Did someone already bought the flood sensor ?
Is it supported by domoticz/OpenZwave ?
If other devices are zwave+, flood sensor should be too.
- LouiS22
I didn't make xml for the flood sensor, but it's not that hard to provide it to OZW, takes about 20 minutesnmaster wrote:Thanks Goldwing1973.
And yes, it's zwave+: http://www.pepper1.net/zwavedb/device/960
nmaster
Thanks LouiS22, ordered a wall plug and a flood sensor.
I'll test the flood sensor, I never created xml file for OZW, but I will take a look.
Derik
The motion sensor from coolcam....
a big disappointment
He responds on everything unfortunately not only on humans and animals.
Also my threes is reacting etc etc
- LouiS22
Have you tried every configuration options?Derik wrote:The motion sensor from coolcam....
a big disappointment![]()
Derik
wish there where settings:
Doler
Now also at Robbshop: https://www.robbshop.nl/tussenstekker-2 ... eo-coolcam
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
- Domosapiens
- Domoticz version: V3.5981
@Derik,
if you don't have the configuration menus/help as shown here ...
https://github.com/domoticz/domoticz/bl ... -pd01z.xml
then your node is not correct included
or ... you have a Domoticz version more than a month old.
juankar
- Domoticz version: 4.
In our country it's a reality that "cheap chinese product" is a "bad quality product"... And some times an "expensive chinese product" is a "bad quality product" too, like Philio.
