pool temperature sensor TFA 30.3216.20
Dirkie
Domoticz version: 2.4075
Post by Dirkie »
I hava a pool temperature sensor TFA 30.3216.20 installed. At my devices it is shown as a TFA 30.3133 with a temperature of 0 degrees celcius and it is actualy 27 at this moment 8-)
Is there a method to change the reading so the correct values are shown?
Devices: Synology diskstation; RFXtrx433
Synology Diskstation; RFXtrx 433.92MHz
Dennist1985
Domoticz version: 4.10717
Re: pool temperature sensor TFA 30.3216.20
Post by Dennist1985 »
Click the temperature tab.
Then click edit from your pool sensor and type 27 in the adjustment box.
Now it's always showing 27 degrees more then what he measuring.
Dirkie
Post by Dirkie »
I've tried this already but the temperature doesn'nt change in domoticz when it changes in the pool...
Derik
Post by Derik »
Show some screendumps...
Dirkie
Post by Dirkie »
this is how the sensor is recognized by Domoticz
as I wrote eralier, donoticz thinks it is a 30.3133 insted of a 30.3216.20
ervine
Post by ervine »
I have the same unit, also recognized as a 3133. In my case however temp readings work.
b_weijenberg
Post by b_weijenberg »
The 30.3216.20 for the TFA 30.3056.10 is supported in Ext2 firmware version 1007 for the RFXtrx433E.
Enable the Oregon protocol for this TFA sensor!
On request a Type1 firmware for the RFXtrx433 can be provided by RFXCOM.
RFX-433, RFX-433EMC, RFX-868
Derik
Post by Derik »
mmm did have last year this sensor working...
Now the summer is here..
I try to add the sensor again.
See the value on the screen.
New battery
pus the tx button servel time.
Replace new battery..
Set the good protocol...
No sensor...
Bert where do i go wrong??
Think to much protocols enabled....
Only witch 2 hate each other?
b_weijenberg
check with RFXmngr if the sensor is received with only TFA enabled
