I want monitor the used time of my heating. There are any dummy device to do it?
I speak about see in log details the total time used per day like you can do with total Watts per day...
Best regards!
Time of use per day in statics
ayasystems
Fronius plugin
https://github.com/ayasystems/froniusHttp
Solax plugin
https://github.com/ayasystems/SolaxHTTP
Openevse plugin
https://github.com/ayasystems/OpenEVSEPlugin
Solax plugin
Openevse plugin
- Egregius
- Domoticz version: v2024.7
Re: Time of use per day in statics
Some example code:
It grabs the history of idx 131 (my gas burner) and loops thru the result to calculate the total hours on in the last day.
echo '<table>';
$datas = json_decode(file_get_contents($domoticzurl.'json.htm?type=lightlog&idx=131',true,$ctx),true);
$status = '';$tijdprev = $time;$totalon = 0;
if(!empty($datas['result'])) {
foreach($datas['result'] as $data) {
if($status!=$data['Status']) {
$status=$data['Status'];
$level=$data['Level'];
$tijd = strtotime($data['Date']);
if($tijd<$eendag) break;
$period = ($tijdprev - $tijd);
if($status=='On') $totalon = $totalon + $period;
$tijdprev = $tijd;
echo '<tr align="right"><td>'.$data['Date'].'</td><td> '.$status.' </td><td> '.convertToHoursMins($period/60).'</td></tr>';
echo '</table>';
function convertToHoursMins($time, $format = '%01d u %02d min') {if ($time < 1) return;$hours = floor($time / 60);$minutes = ($time % 60);return sprintf($format, $hours, $minutes);}
ayasystems
Thanks for your script
But your script is to generate a table out of domoticz web interface.
Add these feature into domoticz will be fantastic!
Fronius plugin
Solax plugin
Openevse plugin
Solax plugin
Openevse plugin
- Egregius
That's true, the best way to have things exactly as you want it.
ayasystems
Where must be put your code??
Fronius plugin
Solax plugin
Openevse plugin
Solax plugin
Openevse plugin
- Egregius
It's PHP code so you need a php enabled web server like Apache2 or nginx.
