Time of use per day in statics
ayasystems
Post by ayasystems »
I want monitor the used time of my heating. There are any dummy device to do it?
I speak about see in log details the total time used per day like you can do with total Watts per day...
Best regards!
Egregius
Domoticz version: v2024.7
Re: Time of use per day in statics
Post by Egregius »
Some example code:
echo '<table>';
        $datas = json_decode(file_get_contents($domoticzurl.'json.htm?type=lightlog&idx=131',true,$ctx),true);
        $status = '';$tijdprev = $time;$totalon = 0;
        if(!empty($datas['result'])) {
            foreach($datas['result'] as $data) {
                if($status!=$data['Status']) {
                    $status=$data['Status'];
                    $level=$data['Level'];
                    $tijd = strtotime($data['Date']);
                    if($tijd<$eendag) break;
                    $period = ($tijdprev - $tijd);
                    if($status=='On') $totalon = $totalon + $period;
                    $tijdprev = $tijd;
                    echo '<tr align="right"><td>'.$data['Date'].'</td><td>&nbsp;'.$status.'&nbsp;</td><td>&nbsp;'.convertToHoursMins($period/60).'</td></tr>';
        echo '</table>';
function convertToHoursMins($time, $format = '%01d u %02d min') {if ($time < 1) return;$hours = floor($time / 60);$minutes = ($time % 60);return sprintf($format, $hours, $minutes);}
It grabs the history of idx 131 (my gas burner) and loops thru the result to calculate the total hours on in the last day.
ayasystems
Thanks for your script
But your script is to generate a table out of domoticz web interface.
Add these feature into domoticz will be fantastic!
Egregius
Post by Egregius »
That's true, the best way to have things exactly as you want it.
ayasystems
Where must be put your code??
Egregius
Post by Egregius »
It's PHP code so you need a php enabled web server like Apache2 or nginx.
