Hi, i am Harold form Holland and a newbe.
Need some help.
I try to get the program working.
Plugged the RFXtrx433E in the usb poort, start the domoticz software.
But what do i have to do more?
On start up it says, no favorite devices defined or commiunication lost.
In hardware the Rfx is put on com6.
In devices the re is nothing to select.
What do i wrong?
(Sorry if the englsh is a bit wrong.)
Newbe Topic is solved
- Domoticz version: 2022.2
Re: Newbe
Check this page in the wiki: https://www.domoticz.com/wiki/Hardware_Setup
tip: use google (a lot)
Succes, Jan
Succes, Jan
- emme
- Domoticz version: latest
Re: Newbe
RFXCom needs to be configured with the supported protocols....
I have one to connect some Oregon Scientific devices and remote/security devices.
To add them I had to configure the hardware device with Oregon and lightning4 (CHUANGO PIR, Remotes, gas/flood detector and contacts) protocol
Security devices can be easy added by following the manufactor instruction.
for OS devices I simply had to wait and they appear in the device list
For lightning5 devices, I had to add a new intelligent switch
ciao
M
ciao
M
"We always done this way"
Re: Newbe
Jan, looks like you talk Dutch.jannl wrote:Check this page in the wiki: https://www.domoticz.com/wiki/Hardware_Setup
Succes, Jan
Is there a way we can speak again?
