sensor data to shell script
Robban
I wonder how i retreive a sensordata (ex temperature) to a shell script?
i want my pi to say the temperature in a scenario
Robert
Robert
- Egregius
- Domoticz version: v2024.7
Re: sensor data to shell script
Did you look at the json commands in the wiki?
Maybe this is a starting point. I use this script to let my iMac go to sleep depending on 3 switches in Domoticz:
The script grabs the sensors from roomplan 7 (so it only get the 3 switches instead of all used devices).
The litle jsonValue function decodes the json data and puts the status in variables.
Is one of the variables can't be set, the scripts exits.
If one of 3 statusses is 'On' a second script is called.
#!/bin/bash
function jsonValue() {
KEY=$1
num=$2
awk -F"[,:}]" '{for(i=1;i<=NF;i++){if($i~/'$KEY'\042/){print $(i+1)}}}' | tr -d '"' | sed -n ${num}p
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://192.168.0.10:8084/json.htm?type=devices&used=true&plan=7"`
if [ -z "$DOMOTICZ" ]
then
exit 1
WEG=$(echo $DOMOTICZ | jsonValue Status 1)
SLAPEN=$(echo $DOMOTICZ | jsonValue Status 2)
IMACSLAPEN=$(echo $DOMOTICZ | jsonValue Status 3)
if [[ -z "$WEG" || -z "$SLAPEN" || -z "$IMACSLAPEN" ]] ;
then
exit 1
fi
if [ $WEG == "On" ] || [ $SLAPEN == "On" ] || [ $IMACSLAPEN == "On" ]; then
/Applications/MyApps/imacsleep.command
fi
fi
Robban
i can call a webpage to get the data from a sensor, but i want to extract the Data value in a sh script
cant find it anywhere
Robban
can´t figure out how to mask out a ex temperature data from a shell script.
lika i said i can call a website with the temperatue status, adress etc
- Egregius
Maybe you should post your code? And explain better what you want?
Do you want to grab a temperature from a website and push it to domoticz? Or do you want to rab a temperature from Domoticz and use it in a shell script?
Robban
yes, i have voicerss working .
and i want a shell script that says ex " Godmorning, the outside temperature is xx degress.
the temperature is taken from a sensor inside the domoticz
- Egregius
This should get you starting:
The variable $TEMP contains the temperature of thermometer with idx 278.
Value is for ex 20.40 so you should trim that a bit I guess.
#!/bin/bash
KEY=$1
num=$2
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://192.168.0.10:8084/json.htm?type=devices&rid=278"`
then
exit 1
TEMP=$(echo $DOMOTICZ | jsonValue Temp 1)
echo $TEMP
fi
Robban
THANKS ALOT!. worked fine
Robban
noticed that i got temperature like 18,80 , how do i get it to 18.8?
- Egregius
Do you get 18 comma 80 or 18 point 80?
Wouldn't it be better to just remove the decimal and just say the whole degrees?
Then you could use something like this:
Change TEMPCLEAN=${TEMP%.*} to TEMPCLEAN=${TEMP%,*} if comma is your decimal separator.
#!/bin/bash
KEY=$1
num=$2
then
exit 1
echo $TEMP $TEMPCLEAN
fi-
Robban
that did it! THANKS!
