Re: Domoticz app 2.0
Strange, indeed on the website lack weekly charts, there are only a daily, monthly and yearly graphs.
I have not seen this before (I think I was blind).
maluko
I use the dark theme, at last update on change servers tab the server cant see because the color font its the same of background.
thanks.
thanks.
- galadril
- Domoticz version: latest
This should already be fixed in the beta version..maluko wrote:I use the dark theme, at last update on change servers tab the server cant see because the color font its the same of background
Domoticz Android app:
https://play.google.com/store/apps/deta ... s.domoticz
bvduijv
Someone else having problem with the Setpoint functionality? Still having issues with this..
"Unable to get the server configuration info"?
All the other items are working perfectly fine!
- RoadXY
- Domoticz version: 2.2331
The app tried to get the server info but that should be unrelated to your set point
bvduijv
Re: RE: Re: Domoticz app 2.0
But all other items are working fine..without this message? Why is the message displayed, kinda strange?RoadXY wrote:The app tried to get the server info but that should be unrelated to your set point
Next to this x.5 temperatures doesn't work either. You have to press twice to change the Setpoint. Maybe you can take a look at this? Would be nice before the cold winters (or cold summers [PERSEVERING FACE])
maluko
galadril wrote:This should already be fixed in the beta version..maluko wrote:I use the dark theme, at last update on change servers tab the server cant see because the color font its the same of background
hi galadril
i have the last update and it continues to do the same bug.
thanks
Have been running the lite version for some time and wanted to upgrade to the premium.
Unfortunately google play store says: "your device is incompatible with this version"
So there's no install button.
Running an ASUS Google Nexus 7 (2012) tablet with Android 5.1.1
Any idea why this can't run the current Domoticz app ?
- galadril
Working on it.. there is a new beta coming..maluko wrote: i have the last update and it continues to do the same bug.
- galadril
Weird.. this should work..Timdgr wrote:... "your device is incompatible with this version"...
Ill look into the manifest
- galadril
From the play store device compatibility list:galadril wrote:Weird.. this should work..Timdgr wrote:... "your device is incompatible with this version"...
piokuc
I found next bug. In dark theme list to select language is blank and is show on white background. I dont see name languages to select. But should be show on dark background. In white theme all is ok and list select language is show ok andbi see name languages to select.
Next bug In dashboard as grid test on all devices (grids) should be center. Now for some is center and for some is aligment to left. No looks good.
BakSeeDaa
Same problem here. I can't see that Your comment has been answered so I wonder if it has been considered to add x509 support it in the future or not.nayr wrote:Unfortunately, I cannot use this app because it does not support authentication with client tls certificates (x509)..
piokuc
Hi problem with list languages on dark theme was resolved. Thank.
But problem with aligment on dashboard is still not resolved.
maluko
galadril wrote:Working on it.. there is a new beta coming..maluko wrote: i have the last update and it continues to do the same bug.
new beta on but bug continues...
- Shaggie_NB
I'm still having problems with the graphs from the Gas and CO2 meters (they won't show). For Electricity and Temp they are working OK!
In the Domotictz (website) they are all working fine...
This was already mentioned by me but everybody was so busy with all the new (and great!) functionalities I thougt it would be picked up later.....
So here is my question again...
- galadril
Can you create a read-only account for me and PM me de details?Shaggie_NB wrote:I'm still having problems with the graphs from the Gas and CO2 meters (they won't show). For Electricity and Temp they are working OK!
NiklasO
- Target OS: -
Can't control blinds from the widget?
Would like to see "Open" and/or "Close" button.
Edit
Well. Sometimes it shows "Off"-button but switches the wrong device.
Edit
Last edited by NiklasO on Saturday 03 September 2016 21:01, edited 1 time in total.
cogliostrio
I get the same error when trying to adjust a setpoint which is not working/not correctly configured. Have youbvduijv wrote:Someone else having problem with the Setpoint functionality? Still having issues with this..
verified that it works from the web interface?
bvduijv
The message is gone after a reinstall of the app. I noticed that the message was not there on other devices.cogliostrio wrote:I get the same error when trying to adjust a setpoint which is not working/not correctly configured. Have youbvduijv wrote:Someone else having problem with the Setpoint functionality? Still having issues with this..
Although, the Setpoint is still not working fine if the temp is set to a x.5 temp. Than I have to press twice to adjust it. Do you also have this issue?
