I have the Z-Wave GreenWave PowerNode 1 (http://www.allcontroll.no/produkt/smartkontakt/) and it works very good, exception for one problem
occasionally lose the signal (I think), the background becomes red (screenshot.308.png).
And in the measures I haven't details each five minutes but, for example I lose the measures of 21:30 o 9:30 (screenshot.309.png).
If I turn on the node from the list of switches, back with white background.
Do you know if after a specified time automatically goes into standby mode or if there is a problem?
GreenWave PowerNode goes into standby mode
bigpea
- screenshot.309.png (39.39 KiB) Viewed 1159 times
- screenshot.308.png (2.62 KiB) Viewed 1159 times
- Egregius
- Domoticz version: v2024.7
Re: GreenWave PowerNode goes into standby mode
The Greenwave nodes like polling. Do you have it enabled for that node? Maybe with a very long polling interval, like ex 300 seconds.
bigpea
No, the polling is disabled.
I will try in this way, I let you know in the next days the result.
Thanks.
Thanks.
trixwood
I thought I was the only one having problems with powernode,
I have 3 powernodes 1, they all stop working after some time, if I do not poll them. I get gaps between readings, eventhou the power is changing, and after a couple of days they start the blink green and will not connect unless I restart domoticz (or the z-wave usb controller hardware)... bringing a cascade effect on the other sensors connected to the usb controller through the powernode...
With polling, they work perfectly... and all the other sensors keep working...
bigpea
with polling works, however I seen that the spleepeng is a very intelligent management system, when the greenwave receives a command from the server, or a change in consumption from the appliance connected, is reactivated.
