As asked in viewtopic.php?f=23&t=9489 it would be really nice to be able to run system scripts (bash, python, whatever) from Blocky.
LUA is nice, but putting a sleep in LUA will cause it to run multiple times sequential, which really is a killer for scripts.
A Blocky option 'execute $script after $time' would be a great addition to the Domoticz OS in my opinion.
Cheers.
[667] Ability to execute script:/// from Blocky
void
tracker.php?p=2&t=667
Ritmeester
Re: [667] Ability to execute script:/// from Blocky
+10
Absolute a good idea.
Muyz
+10
This is indeed a very good suggestion. I have been using Domoticz only for one week and it's exactly what I need.
raym
You could call a script from a dummy switch and then call that switch from blocky.
- gizmocuz
Implemented in beta #5437
if you enter an IDX in between {{ and }} , from for example a temperature sensor, it is replaced with the value of this sensor
Hope all is working well....
fransiefrans
- Domoticz version: stable
Sounds good! I will try this tonight. Thanks
- gizmocuz
Forgot to mention... you can find it under the 'messages' section... not sure if it is the logical place, but as open_url was also in here....
fransiefrans
I'm unable to update to the latest beta version. After 2% it says error internet connection.
bearded
Works great for me. I'm triggering batch files to run in Windows directly from blockly now rather than having to run them from switches. Really useful functionality, thanks!
Muyz
Great! Now I will move from stable to latest greatest
jonazp
I cant seem to run a script within blockly. I get error 32512.
The script works fine when run fron putty or with a switch that calls the script.
Any ideas?
Any ideas?
bearded
My scripts run batch files (on Windows) which are contained in the 'domoticz' folder and therefore do not need a path specifying. (i.e. just 'tv-on.bat with no / or \ required.) Maybe the problem is when you specify a path in blockly? Try moving a file into your domoticz root folder and executing it as I do. Could be a bug in blockly.
jonazp
Cant get it to work
- heggink
- Domoticz version: 12451
I noticed that in some cases, starting a script without any parameters results in an error as follows:
Error executing script command (/home/pi/domoticz/scripts/say_ad.sh#). returned: 32512
If I add a space after the script's name then the # is still there but taken as the first parameter of the script (where my script doesn't use any so it works as a workaround).
Anyone else seen this? Obviously only applies to linux( /raspbian).
H
H
P1 meter & solar panel
mikkel75
I see the exact same - I'll try the workaround and report back.... Thanks...
(I'm on x86_64 Ubuntu 16.04)
mikkel75
The space workaround works - but why is there a tailing '#' when the script is called?
sjoerd1953
- Domoticz version: 2020.2
Works great with me. Thanks a lot for this improvement. A few notes:
When Domoticz is running on a Raspberry Pi and you place the bash script in a seperate folder (e.g. /home/pi/domoticz/scripts/bash) then, next to making the script executable with CHMOD 755 you also have to add the folder to your $PATH. You can do this by adding this code to your .profile file and reboot. Use the full directory name as mentioned above.
You will find the .profile file in the /home/pi directory as a hidden file. Add the code at the bottom of the file.
I use this to set Milight bulbs to nightlight at sunset. This is the bash code:
and this the Blockly code:
at sunrise they go out again with:
and this:
export PATH=$PATH:directory nameI use this to set Milight bulbs to nightlight at sunset. This is the bash code:
#!/bin/bash
echo -n -e "\x33\x00" | nc -u -q 1 192.168.2.25 8899 # set zone 2 OFF
echo -n -e "\x3A\x00" | nc -u -q 1 192.168.2.25 8899 # set zone 3 OFF
echo -n -e "\x36\x00" | nc -u -q 1 192.168.2.25 8899 # set zone 4 OFF
sleep 1
echo -n -e "\xB3\x00" | nc -u -q 1 192.168.2.25 8899 # set zone 2 NightLight
echo -n -e "\xBA\x00" | nc -u -q 1 192.168.2.25 8899 # set zone 3 NightLight
echo -n -e "\xB6\x00" | nc -u -q 1 192.168.2.25 8899 # set zone 4 NightLightCode: Select all
#!/bin/bash
Sjoerd van Staveren
Domoticz running on a Raspberry Pi 3; Milight RGBW and Dual White bulbs; RFXcom XL;HOMEeasy switch; Flamingo switches; Sonoff switches
Oxyandy
Run local batch file Windows
Hi I have Windows 10
have tried a bunch of different syntax - log says
2018-02-22 18:37:13.940 Executing script: 'C:\_\done.bat '#
But it never fires the batch file
help please
help please
htilly
Hi! Having the same problem. Did you figure out why there is a tailing # ?!
It's messing up my scripting! =)
mikkel75 wrote: Thursday 19 January 2017 12:09 The space workaround works - but why is there a tailing '#' when the script is called?
