I'm installing Domoticz in a RPI 3 with RFXtrx433E, I read a lot about this configuration but I have a problem. When I add RFXtrx433E like a Hardware in Domoticz, some devices will have to appear in Devices but, in my case, any devices appear and I can't configurate any device. ¿Anyone know what can I do?
Thanks,
I can't see devices when RFXtrx433E is added
antwan
- Domoticz version: Latest
Re: I can't see devices when RFXtrx433E is added
Cloud you be more specific? Maybe add Some screenshots?
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
- LouiS22
Have you enabled the accept new hardwere option at all and have you enabled the respective protocols you want to decode?
dpui7736
- Domoticz version: 4.9700
Yes, when I add the hardware RFXantwan wrote:Cloud you be more specific? Maybe add Some screenshots?
https://drive.google.com/open?id=0Bw-M4 ... DdJQ3pKVkE
And I go to devices and search some rfx devices I can't see any device
https://drive.google.com/open?id=0Bw-M4 ... m11eXp6UGs
I read this tutorial to configure RFX in domoticz
http://www.vesternet.com/resources/appl ... 6zXRJiLS71
dpui7736
Yes, I accept new hardware in configurationLouiS22 wrote:Have you enabled the accept new hardwere option at all and have you enabled the respective protocols you want to decode?
https://drive.google.com/open?id=0Bw-M4 ... TgyUHU3UjQ
Yes, I did this like this tutorial say
Thank you,
b_weijenberg
- Target OS: -
Do you receive sensors in RFXmngr on a Windows system?
Is the RFXtrx433E antenna not too close to the RPI3?
RFX-433, RFX-433EMC, RFX-868
dpui7736
Thank you for your responses, I solved the problem creating new switches to controll my blinds. In my case I only need to controll receive devices and I need to create first the switch.
