homebridge-edomoticz Plugin
Marci
Domoticz version: 3.8153
eDomoticz Homebridge-Plugin
Post by Marci »
RduPre wrote:Hi Guys,
Sorry to jump in here.
I'm a Homeseer user and using the Homebridge shim for Homeseer based on the same architecture.
I read that you also implemented Custom HomeKit Types, like:
General kWh power meters - Types: General, Current, Usage; SubType: kWh, Electric (inc CurrentCost USB)
YouLess Meter (Current, Total and Today Total Consumption) - Type: YouLess Meter; SubType: YouLess counter
EvoHome / OpenTherm Thermostat support - Types: Heating, Thermostat; SubTypes: Zone, SetPoint
General Usage % meters (eg: Motherboard Sensors Hardware Device - CPU %, Mem %, HDD % etc) - Type: General; SubType: Percentage
Temperature, Temp + Humidity, Temp + Humidity + Baro (Current Temperature, Current Humidity, Current Pressure in hPA) - Type: Temp, Temp + Humidty, Temp + Humidity + Baro
DarkSkies Virtual Weather Station Sensors (Wind, Solar Radiation, Rainfall, Visibility, Barometer)
Location Sensor - any Domoticz text sensor with "Location" in it's title, for use with custom GeoFence / Bluetooth scripts.
Because the types not supported by HomeKit itself, I was wondering how you did this?
Many thanks in advance,
Rien
By defining the custom service and character definitions... have a look at the source on GitHub - in lib/services.js for the MQTT branch, or in index.js in the master branch.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
deejc
Domoticz version: 3.5641
Re: eDomoticz Homebridge-Plugin
Post by deejc »
Marci wrote:Can do, aye...
forever seems to create randomly named logs, is there a way to get it to write home bridge.log in ~/.forever ? so i can then add it to log rotate ?
i tried
forever -l ~/.forever/homebridge.log restart /usr/local/lib/node_modules/homebridge/bin/homebridge
but it didn't work
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
Marci
Post by Marci »
See https://github.com/foreverjs/forever but you'll probably need to stop it and start it rather than restart it.
Might have to use -o instead of -l and at a guess the file will need to exist.
Marci
Post by Marci »
Dammit - have created a problem somewhere... lasts an hour then a whole pile of sensors and switches vanish... From 65 down to 11.
MQTT branch currently broken - sorry folks!
They return after a homebridge restart, but end up vanishing again...
deejc
Post by deejc »
seems it's
forever -a -l homebridge.log start /usr/local/lib/node_modules/homebridge/bin/homebridge
seems to work now, got log rotate setup for it.
i have some devices not showing properly in Home app, will go through and get the json out put but one if the you less meter not showing me anything in home app, just shows "on" and the others are netatmo air quality sensors, also just how "On"
Marci
Post by Marci »
Yup - fire over json & I'll take a look over next few days.
deejc
Post by deejc »
i thought you added youless as 1 of the first items when you first started this plugin, but this is the output for it anyway
   "ActTime" : 1470948170,
   "ServerTime" : "2016-08-11 21:42:50",
   "Sunrise" : "05:42",
   "Sunset" : "20:29",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "Counter" : "19311.648",
         "CounterToday" : "10.000 kWh",
         "CustomImage" : 0,
         "Data" : "19311.648 kWh 338 Watt",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 4,
         "HardwareName" : "youless",
         "HardwareType" : "YouLess Meter with LAN interface",
         "HardwareTypeVal" : 6,
         "HaveTimeout" : false,
         "ID" : "80",
         "LastUpdate" : "2016-08-11 21:42:43",
         "Name" : "YouLess",
         "Notifications" : "false",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "YouLess counter",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "YouLess Meter",
         "TypeImg" : "counter",
         "Unit" : 1,
         "Usage" : "338 Watt",
         "Used" : 1,
         "ValueQuantity" : "",
         "ValueUnits" : "",
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "2"
   "status" : "OK",
   "title" : "Devices"
[8/11/2016, 9:50:55 PM] [eDomoticz] { Battery: 255,
  RSSI: 12,
  dtype: 'YouLess Meter',
  idx: 2,
  nvalue: 0,
  stype: 'YouLess counter',
  svalue1: '19311697',
  svalue2: '436',
  unit: 1 }
and here is one of the air quality
   "ActTime" : 1470948301,
   "ServerTime" : "2016-08-11 21:45:01",
   "Sunset" : "20:29",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "614 ppm",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 3,
         "HardwareName" : "netatmo",
         "HardwareType" : "Netatmo",
         "HardwareTypeVal" : 54,
         "ID" : "00BD",
         "LastUpdate" : "2016-08-11 21:35:11",
         "Name" : "Lounge Air Quality",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Quality" : "Excellent",
         "SubType" : "Voltcraft CO-20",
         "Timers" : "false",
         "Type" : "Air Quality",
         "TypeImg" : "air",
         "Unit" : 102,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "7"
   "status" : "OK",
   "title" : "Devices"
[8/11/2016, 9:15:09 PM] [eDomoticz] { Battery: 255,
  RSSI: 12,
  dtype: 'Air Quality',
  idx: 7,
  name: 'Lounge Air Quality',
  nvalue: 540,
  stype: 'Voltcraft CO-20',
  unit: 102 }
Marci
Post by Marci »
I did, but the MQTT handler is still experimental...
I also need an MQTT message sample for each device too please!
deejc
Post by deejc »
fair enough :D
and i do appreciate all your work, it works more or less out of the box and i know there is so much going on under the hood!!
btw, the mqtt messages are so quick the iOS home app updates before the actual light turns off in my living room :geek:
deejc
Post by deejc »
Marci wrote:I also need an MQTT message sample for each device too please!
i think i got it in the post above, thats whats in the log
Marci
Post by Marci »
So you did... Soz!
max_g
Post by max_g »
this is very interesting, Marci your work is much appreciated.
when open technology starts utilising the innovation that smart software developers bring, the combination becomes incredible powerfull
Marci
Post by Marci »
deejc wrote: i think i got it in the post above, thats whats in the log
Head to your homebridge-edomoticz folder, run...
cd lib/
sudo rm domoticz_accessory.js
sudo wget https://raw.githubusercontent.com/PatchworkBoy/homebridge-eDomoticz/mqtt-integration/lib/domoticz_accessory.js
...then restart Homebridge. Air Quality should now be supported and YouLess fixed.
Point to note: MQTT can only update air particulate density as that’s all it sends in the MQTT message. Overall Air Quality (Excellent / Fair / Poor etc) can only be retrieved via a pull-to-refresh / old-style http request.
simon_rb
Post by simon_rb »
Are we close to a general release this weekend Marci?
Marci
Post by Marci »
Not sure yet - there’s still something which occurs that causes me to randomly lose 54 devices in one hit, until homebridge is restarted. Don’t want to let it properly loose til I’ve established the cause... as once it loses them, you have lost all room assignments / scene assignments etc for those devices.
simon_rb
Post by simon_rb »
Marci wrote:Not sure yet - there’s still something which occurs that causes me to randomly lose 54 devices in one hit, until homebridge is restarted. Don’t want to let it properly loose til I’ve established the cause... as once it loses them, you have lost all room assignments / scene assignments etc for those devices.
Ok mate, good luck! Lol
Marci
Post by Marci »
@TheRamon - here’s something genius I’ve noticed...
Get it all up and running, and run homebridge in debug mode ala:
DEBUG=* /usr/local/bin/homebridge -D >> /var/log/homebridge.log
Then open a new terminal window in which to tail -f /var/log/homebridge.log
Now, open Eve, and you can see all the characteristics register for events for your devices IP Address. Close Eve, and all the characteristics unregister for events for your devices IP Address... UNLESS those characteristics are associated with a rule or trigger that requires that characteristic to remain registered. Either way, every now and again a keepalive is sent to all clients it’s aware of.
When next that device reregisters for events (ie: Eve is foregrounded again), it fires off a mass queue of things it’s missed to bring the client up to date.
So, that’s how battery life and bandwidth hit on the device is minimised.
deejc
Post by deejc »
Marci wrote: Head to your homebridge-edomoticz folder, run...
<Snip>
The air quality is actually the part that works :D
youless is still showing "off"
Marci
Post by Marci »
Repeat...
cd lib/
...then restart Homebridge. Let me know!
deejc
Post by deejc »
Marci wrote:Repeat..
nah, still the same except now it says it "on" :!:
