Does anyone have zwave-plus based sensors working along with PowerMeter Reporting?
I am looking for:
Controller : aeon-zstick-gen5
Motion : Fibaro v3.2
Door : Fibaro v3.2
PowerMeter : TKB TZ88e with GEN5 -----> this is not reporting power along with above combination.
I am using domoticz v3.483, OZW v1.4.1
Is there any other GEN5 based power usage reporting sensors that work?
thanks.
Zwave-Plus -- Not Reporting Power Usage
- StanHD
Re: Zwave-Plus -- Not Reporting Power Usage
Hi, I have a TZ88, it reports power usage if you enable poling.
Python:- Broadlink RM2, Sonos
kman
Hi Stan,
just to confirm - Is your TZ88e a GEN5 and you are using in the zwavePlus network? i.e. the controller and other sensors are all Zwave-Plus?. So, does it report power usage in this combination.
Even if one of the sensors is Zwave-Only, then even the network will drop to zwave-only mode.
(more specifically)Does your network have aeon-zstick-Gen5 and Fibaro-Motion with v3.2?
thanks.
thanks.
- StanHD
Z-Stick Gen-5
1 x TZ88e - Lib Ver 3, Protocol Ver 3.83, Application Ver 1.10
2 x AN-157 - Lib Ver 4, Protocol Ver 2.64, Application Ver 1.02
6 x FGMS-001 - Lib Ver 3, Protocol Ver 3.67, Application Ver 2.07
3 x FGK-101 - Lib Ver 3, Protocol Ver 3.67, Application Ver 2.05
1 x FGS-222 - Lib Ver 3, Protocol Ver 3.52, Application Ver 2.02
So a mixed system
So a mixed system
