P1 Smart meter to display the separate Phases
DennisP
Post by DennisP »
Dear People,
Is it possible to display the seperate phases from a Smart meter?
I'm using a serial to USB converter cable that is working and showing now only the total and the current power consumption.
grt Dennis
bbqkees
Domoticz version: 4.1x
Re: P1 Smart meter to display the separate Phases
Post by bbqkees »
No it is not.
The meter does not output the separate phase data, it is already combined in the datagram.
DennisP
Post by DennisP »
I tested the cable with the tools from smartmeterdashbaord.com and i got a telegram with the current power per phase (L1, L2 and L3) so i think it should be possible but how?
bbqkees
Post by bbqkees »
Ok I thought you meant total power. In my meter datagram it is all added to one total.
Well if it's in the datagram you should be able to get it out.
Likely the code in Domoticz needs to be changed a bit.
