Problems worh using mysensors
trixwood
Re: Problems worh using mysensors
Post by trixwood »
This can work, but it get loose a lot...
Photo on 01-08-16 at 18.56.jpg (38.07 KiB) Viewed 4589 times
Photo on 01-08-16 at 17.56.jpg (41.68 KiB) Viewed 4589 times
nRF24L01+ btw.
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
TSM:FPAR
TSM:FPAR
TSM:FPAR
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
This is the output you get when the radio is not working.
Look at the output of a sensor with a loose capacitor. You can see where I pressed it ;-) And the point I really pushed to get a connection. I would solder it ;-)
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSM:FPAR
TSM:FPAR
TSM:FPAR
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSM:FPAR
TSM:FPAR
TSM:FPAR
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
TSP:MSG:FPAR RES (ID=0, dist=0)
TSP:MSG:PAR OK (ID=0, dist=1)
TSM:FPAR:OK
TSM:ID
TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
TSM:ID
TSM:ID
TSM:ID
!TSM:CHKID:FAIL (ID=255)
!TSM:FAILURE
TSM:PDT
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSM:FPAR:OK
TSM:ID
TSM:ID
TSM:ID
TSM:ID
!TSM:FAILURE
TSM:PDT
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSM:FPAR
TSM:FPAR
TSM:FPAR:OK
TSM:ID
TSM:ID
TSP:MSG:READ 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:1
TSP:ASSIGNID:OK (ID=1)
TSM:CHKID:OK (ID=1)
TSM:UPL
TSP:PING:SEND (dest=0)
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
TSP:MSG:PONG RECV (hops=1)
TSP:CHKUPL:OK
TSM:UPL:OK
TSM:READY
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=ok:MySensors TempHum
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=ok:2.02
TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
Request registration...
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
Node registration=1
Init complete, id=1, parent=0, distance=1, registration=1
TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:5.046
TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:81
TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:29.8
TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:38.7
TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:28.0
TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.3
TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:27.9
TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:41.1
TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:40.7
!TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=fail:40.5
!TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=1,st=fail:40.6
!TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=2,st=fail:41.0
!TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=3,st=fail:41.2
!TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=4,st=fail:27.8
!TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=5,st=fail:41.0
!TSM:UPL FAIL, SNP
TSM:FPAR
TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
TSM:FPAR
!TSP:SEND:TNR
TSM:FPAR
TSM:FPAR
!TSP:SEND:TNR
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
!TSP:SEND:TNR
!TSP:SEND:TNR
!TSP:SEND:TNR
!TSP:SEND:TNR
!TSP:SEND:TNR
!TSP:SEND:TNR
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSM:FPAR
TSM:FPAR
!TSP:SEND:TNR
!TSP:SEND:TNR
TSM:FPAR
!TSP:SEND:TNR
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
!TSP:SEND:TNR
!TSP:SEND:TNR
!TSP:SEND:TNR
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSM:FPAR
!TSP:SEND:TNR
!TSP:SEND:TNR
TSM:FPAR
TSM:FPAR
Anyway MySensors great, their forum a disaster and information on v2 really really sparse.
And the link mentioned before is missed easily. https://github.com/mysensors/MySensorsArduinoExamples
tlpeter
Post by tlpeter »
I see this sometimes too:
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
It seems that the capacitor is too small in my case.
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
Looks like you have PA+LNA radio - it does require an external power (not from Arduino Nano in your case). Either try to use a normal radio or provide a separate stable 3.3V power to the radio.
alexsh1
Post by alexsh1 »
The above error message means that the node cannot connect to the GW.
