Error, Node047, WARNING: node revived
BakSeeDaa
Post by BakSeeDaa »
Hi there! I need some advice.
I had a FIBARO System FGK101 Door Opening Sensor that stopped working. Now I need to remove it from my list of devices in OpenZWave Control Panel.
There are actually 2 devices that I need to remove. They are listed as follows:
Node Id 	Basic Type 	Generic Type 	Product 	Name 	Location 	Value 	Last Heard 	Status
47 BR	Routing Slave	Routing Binary Sensor	FIBARO System FGK101 Door Opening Sensor	D5		on	09:31:00	CacheLoad (sleeping)
48 BR	Routing Slave	Routing Binary Sensor	FIBARO System FGK101 Door Opening Sensor	OLD		off	09:31:04	Probe (sleeping)
The device is removed and has no battery. When I run the "Has Node Failed" command i get the following in the log:
2016-07-18 08:50:55.106 Error, Node047, WARNING: node revived
2016-07-18 08:50:55.106 Always,
2016-07-18 08:50:55.106 Always, Dumping queued log messages
2016-07-18 08:50:55.106 Always, End of queued log message dump
The status won't change to "Failed" as I would like it to so I can not remove failed devices.
The same goes for node 48. What is the "WARNING: node revived" message trying to tell me and how shall I proceed to delete the 2 ghost devices?
Thanks!!!
Egregius
Domoticz version: v2024.7
Re: Error, Node047, WARNING: node revived
Post by Egregius »
Good question, but a hard one.
I used to use tge 'has node failed' command to revive dead nodes that were just marked as dead.
I also have several real dead nodes in the list. Nodes that are replaced or where I needed to do a hard reset.
No mather what command I choose it seems impossible to remove them.
BakSeeDaa
Post by BakSeeDaa »
Is this a bug? I believe we should be able to delete dead nodes.
BakSeeDaa
Post by BakSeeDaa »
I removed the <CommandClass id="132" name="COMMAND_CLASS_WAKE_UP" entry for both of my nodes as suggested here: https://groups.google.com/forum/#!topic ... yvofYlUMwU
After editing the file, I power cycled the Pi and now the devices where marked as "Dead". I was then able to remove the devices.
Egregius
Post by Egregius »
With what command did you do that?
BakSeeDaa
Post by BakSeeDaa »
Egregius wrote:With what command did you do that?
In OpenZWave Control Panel.
I ran the Controller Operation "Remove Failed Node".
Egregius
Post by Egregius »
Strange, have 2 nodes that are marked as dead but I can't remove them. Already used that command 10 times (or more ;) )
BakSeeDaa
Post by BakSeeDaa »
Egregius wrote:Strange, have 2 nodes that are marked as dead but I can't remove them. Already used that command 10 times (or more ;) )
I might have marked the failed node and ran the Controller Operation "Has Node Failed" command prior to running "Remove Failed Node" (Can't remember right now if I had to) Have You tried that?
Egregius
Post by Egregius »
Will try soon, on vacation now.
Have tried all commands that somewhere sound like they are involved for that.
Egregius
Post by Egregius »
Found a way that works on my system to remove a dead node:
Select node in OZWCP
Controller -> Remove failed node -> Go
Restart domoticz
Without restart of Domoticz the node just stay in the list.
Finally got rid of those 2 dead devices :)
