Amazon Echo to Domoticz Bridge: switches, sensors & more
Alexa, Google Home and Siri
skybehind
Re: RE: Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by skybehind »
Madgeni wrote:That's a very neat solution :)
Are you going to be able to post your updated code? I just set up the ha-bridge but would like to try yours
Sent from my Nexus 6 using Tapatalk
Madgeni
Post by Madgeni »
Bigted
Domoticz version: 2020.1
Post by Bigted »
I'm having a little issue with Alexa discovering my devices
I run through the three test scripts you provided and they all either switch on/off a light or scene, and I get results back from running the discover script
2016-07-21T18:30:35.819Z	33355246-4f71-11e6-ad02-ad61240945fa	{ applianceId: '62',
manufacturerName: 'RFXtrx433',
modelName: 'LightwaveRF',
version: 'On/Off',
friendlyName: 'Hall Lamp',
isReachable: true,
actions:
[ 'incrementPercentage',
'decrementPercentage',
'setPercentage',
'turnOn',
'turnOff' ],
additionalApplianceDetails: { switchis: 'On/Off', WhatAmI: 'light' } }
I see the app at http://www.alexa.amazon.com, but how do I get Alexa to discovery my devices, If I click on Discover devices under Smart Home, Alxa finds my Hue lights and Yonomi devices, but she doesn't pick up anything from Domoticz
Do I need to say something specific for Alexa to discover the Domoticz devices?
Madgeni
Post by Madgeni »
ok, just seen you've used the discovery script in test, and it works?
That should be sufficient - but could you run the test and post (some) of the output here?
Bigted
Post by Bigted »
The discovery script works in test mode
The Log:
2016-07-22T19:57:24.253Z	7e931595-5046-11e6-9ce5-3bc5378b435d	{ applianceId: '504',
manufacturerName: 'Zwave',
modelName: 'Switch',
version: 'On/Off', friendlyName: 'Socket 2',
isReachable: true,
actions:
'setPercentage',
'turnOn',
'turnOff' ],
2016-07-22T19:57:24.312Z	7e931595-5046-11e6-9ce5-3bc5378b435d	{ applianceId: '582',
manufacturerName: 'Dummy',
modelName: 'X10',
version: 'On/Off', friendlyName: 'Mute',
isReachable: true,
actions:  [ 'incrementPercentage', 'decrementPercentage',
'setPercentage',
'turnOn',
'turnOff' ],
2016-07-22T19:57:24.312Z	7e931595-5046-11e6-9ce5-3bc5378b435d	{ applianceId: '600',
manufacturerName: 'Huuie',
modelName: 'RGBW',
version: 'Dimmer', friendlyName: 'Iris',
isReachable: true, actions:  [ 'incrementPercentage',
'decrementPercentage', 'setPercentage',
'turnOn',
'turnOff' ],
additionalApplianceDetails: { switchis: 'Dimmer', WhatAmI: 'light' } }
2016-07-22T19:57:24.312Z	7e931595-5046-11e6-9ce5-3bc5378b435d	Discovery { header:
{ namespace: 'Alexa.ConnectedHome.Discovery',
payloadVersion: '2' },
payload:
{ discoveredAppliances:
[ [Object],
[Object],
[Object],
[Object],
[Object],
[Object],
The Results
  "header": {
    "namespace": "Alexa.ConnectedHome.Discovery",
    "name": "DiscoverAppliancesResponse",
    "payloadVersion": "2"
  "payload": {
    "discoveredAppliances": [
        "applianceId": 201,
        "manufacturerName": "Bedtime",
        "modelName": "Bedtime",
        "version": "1",
        "friendlyName": "Bedtime",
        "isReachable": true,
        "actions": [
          "turnOn",
          "turnOff"
        "additionalApplianceDetails": {
          "WhatAmI": "scene"
        "applianceId": 203,
        "manufacturerName": "Bedroom Telly",
        "modelName": "Bedroom Telly",
        "version": "3",
        "friendlyName": "Bedroom Telly",
        "actions": [
          "turnOn",
          "turnOff"
          "WhatAmI": "scene"
        "applianceId": 204,
        "manufacturerName": "Computer",
        "modelName": "Computer",
        "version": "4",
        "friendlyName": "Computer",
        "actions": [
          "turnOn",
          "turnOff"
          "WhatAmI": "scene"
        "applianceId": "600",
        "manufacturerName": "Huuie",
        "modelName": "RGBW",
        "version": "Dimmer",
        "friendlyName": "Iris",
        "actions": [
          "incrementPercentage",
          "decrementPercentage",
          "setPercentage",
          "turnOn",
          "turnOff"
          "switchis": "Dimmer",
          "WhatAmI": "light"
Madgeni
Post by Madgeni »
you don't say anything to discover - just the regular discovery from the app. It looks ok to me. You should be able to see the logs in Cloudwatch (accessed from lambda) after you've done a discovery, which might shed some light on the disparity between the skill, and the code being executed.
Bigted
Post by Bigted »
Thanks for your help
I didn't think about checking the logs while getting Alexa to discover devices. The log wasn't created. On Lambda I hadn't added Alexa Smart Home as a Trigger :oops: Once that was configured and I reran Discover and refreshed the Alexa page, most of my devices were discovered (went from 9 which were Philips Hue and Yonomi to 67)
Madgeni
Post by Madgeni »
Good catch :)
Bigted
Post by Bigted »
I'm not sure why some of my light switches are not being discovered either by Alexa or the test script. I can't see any difference in the device in Domoticz. device 25 I can understand as its hidden
Only device 15 is being detected, 13,14 & 26 are not discovered.
        "applianceId": "15",
        "manufacturerName": "RFXtrx433",
        "modelName": "LightwaveRF",
        "version": "On/Off",
        "friendlyName": "Christmas Tree",
        "actions": [
          "setPercentage",
          "turnOn",
          "turnOff"
          "switchis": "On/Off",
          "WhatAmI": "light"
Madgeni
Post by Madgeni »
That's strange - can you turn one of them off/on using the test, or does that fail too?
Can you curl it from cmd line?
curl 'http://127.0.0.1:8080/json.htm?type=dev ... order=Name' - see if they all come back?
Bigted
Post by Bigted »
Madgeni wrote:That's strange - can you turn one of them off/on using the test, or does that fail too?
I can turn them all on and off from the test
Madgeni wrote:Can you curl it from cmd line?
All of them are listed
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "RFXtrx433",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "319932",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2016-07-26 14:59:53",
         "Level" : 61,
         "LevelInt" : 20,
         "MaxDimLevel" : 32,
         "Name" : "Bedroom Overhead",
         "Notifications" : "false",
         "PlanID" : "4",
         "PlanIDs" : [ 4, 8, 9 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "LightwaveRF",
         "SwitchType" : "Dimmer",
         "SwitchTypeVal" : 7,
         "Timers" : "false",
         "Type" : "Lighting 5",
         "TypeImg" : "dimmer",
         "Unit" : 3,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "624",
         "YOffset" : "376",
         "idx" : "14"
Madgeni
Post by Madgeni »
Just trying to do some debugging, but it's strange, as long as it's a light (As filtered by Domoticz) i should return it.
If you check the Cloudwatch logs from a test discovery, are they in there?
Apart from your example being a SwitchType 'Dimmer' as per Domoticz, the output is the same as all of mine (i don't have any LightwaveRF dimmer switches, so it's perfectly conceivable i've overlooked something :) )
Bigted
Post by Bigted »
The test discovery doesn't see them either
I have two other LightwaveRF devices which are not dimmers only one of which is discovered
7 - Reading Lamp LightwaveRF On/Off - not found
6 - Uplighter LightwaveRF On/Off - found
Bigted
Post by Bigted »
I've had a little play with my devices. I deleted IDX 7 which wasn't discovered and re-added to the system, this was assigned a new IDX of 609. This device was discovered this time around
Repeated for another device and it was also discovered old IDX 67, new IDX 610
So this may be a work around for me
Madgeni
Post by Madgeni »
ok, it could well be my code :) i'll keep digging, but if you have a work around, then that's..good?
stang
Post by stang »
Thank you very much Madgeni! Using your code and instructions, I was able to make Alexa turn on and turn off a z-wave light bulb. It worked 50% of the time. When it does not work I get a message saying the device does not support "turn off/turn on" command. In the logs I see the same exception many times (pasted at the bottom), but I'm not sure it is related. I will debug it when I have time.
I have a question regarding the Authorization URL and the Access Token URI ( https://ve0kyj5tp5.execute-api.us-east- ... horization and https://ve0kyj5tp5.execute-api.us-east- ... ccessToken). Are these actually used? If these services go down, my home automation will not work? I would prefer to host these myself if possible. It would be great to share the fake OAUTH server code and how to use it.
Another observation: the code does not handle thermostat. I like how Domoticz is hosted locally, but I don't have much free time. I'm tempted to buy SmartThingsi instead of extending myself Domoticz.
Error taken out of Amazon CloudWatch log:
START RequestId: 84933feb-5cfe-11e6-86cb-ff24bcce851d Version: $LATEST
2016-08-08T00:24:49.724Z 84933feb-5cfe-11e6-86cb-ff24bcce851d Input { header:
{ namespace: 'Alexa.ConnectedHome.Control',
payloadVersion: '2',
messageId: 'ab994c71-1210-4caf-89d5-00b5269f5388' },
payload:
{ accessToken: 'AnythingCanBeAToken',
appliance: { applianceId: '1', additionalApplianceDetails: [Object] } } }
2016-08-08T00:24:49.724Z 84933feb-5cfe-11e6-86cb-ff24bcce851d I'm in the Light case
2016-08-08T00:24:49.882Z 84933feb-5cfe-11e6-86cb-ff24bcce851d SyntaxError: Unexpected token u
at Object.parse (native)
at Request._callback (/var/task/node_modules/domoticz-api/api/domoticz.js:69:49)
at self.callback (/var/task/node_modules/domoticz-api/node_modules/request/request.js:200:22)
at emitOne (events.js:77:13)
at Request.emit (events.js:169:7)
at Request.onRequestError (/var/task/node_modules/domoticz-api/node_modules/request/request.js:831:8)
at ClientRequest.emit (events.js:169:7)
at Socket.socketErrorListener (_http_client.js:256:9)
END RequestId: 84933feb-5cfe-11e6-86cb-ff24bcce851d
REPORT RequestId: 84933feb-5cfe-11e6-86cb-ff24bcce851d Duration: 209.76 ms Billed Duration: 300 ms Memory Size: 128 MB Max Memory Used: 32 MB
Process exited before completing request
Madgeni
Post by Madgeni »
Hi there -
clearly it's passing something that the underlying node api wrapper I use doesn't like. Hmm.
Re: Thermostat - agreed, my code is currently only discovering lights/scenes, but can be extended to thermostats also. I don't have one, so its not been on my list to date :)
Re: the Oauth piece - domoticz doesn't handle Oauth2, and this configuration is a dummy one that allows initial setup. It's an interesting Q whether it being down knocks alexa - i'm assuming yes.
Madgeni
Post by Madgeni »
Update - it seems that Amazon changed something - so the friendlyDescription parameter is now mandatory. It wasn't working for me, but after adding that, it now is
Madgeni
Post by Madgeni »
re: setting up Oauth2 - i'd originally wanted to use Amazon account linking - but it wasn't working when i created this. HOWEVER, i've just retested it, and it does - so proper authentication for us now :)
Here someone has kindly put a crib sheet together for what to do: http://stackoverflow.com/questions/3751 ... home-skill
Madgeni
Post by Madgeni »
Just ordered a couple of Amazon Dash buttons - i'm going to see if I can use them to control specific scenes for me using my Echo code. If so, somewhat cheaper and neater than the other options coming up - Fibaro's Button rrp is £40!
