turn a light to "Last state"?
Evelen
- Domoticz version: 2.4538
Hi.
Somtimes I want to change the status of a lamp, f.eks set the light to blue 100% dim for 1 sec, then change it back (as a notification, facebook ect)
eks:
- Color is red 24% dim
- facebook notification = set color blue 100% dim for 1sec
- Set Color back to red 24% dim
or:
- light is off
- light off
Is this posible? as easy as possible.
I only use Blockly until now, but maybe LUA must be used here?
eks:
or:
- light is off
- light off
- Egregius
- Domoticz version: v2024.7
Re: turn a light to "Last state"?
First store the current value in a variable or other cache system.
Set the new color and then read the variable again to set the old one.
Evelen
It sounds logical, but how?
Search for "store variable lua domoticz", i searched for this some time ago and found some examples og storing values with LUA.Evelen wrote:It sounds logical, but how?
- jvdz
- Domoticz version: 4.107
I use this function to temporary change a switch to something and then have it return to its previous state:
Jos
-- Set lights on for a certain time and then revert back to the original state
function TempSwitchChange(DeviceName, Command, Level, TimeSecs)
local dstatus = otherdevices[DeviceName]
local dvalue = otherdevices_svalues[DeviceName]
print("!### TempSwitchChange DeviceName:" ..DeviceName .." Command:" .. Command .." Level:" ..Level .." TimeSecs:" .. TimeSecs)
print(" Current status:" ..dstatus .." dvalue:" .. dvalue)
if dstatus == nil then
-- invalid switch
print(" ==> Invalid switchname " .. DeviceName .. " (" .. ScriptName .. ")")
elseif (dstatus == Command and dstatus == "Set Level" and dvalue == Level) then
-- no change so don't do anything
print(" ==> Nothing to change for " .. DeviceName .. " (" .. ScriptName .. ")")
elseif (dstatus == Command and dstatus ~= "Set Level") then
if Command == "Set Level" then
-- Set future status thorugh LUA
print(" ==> Set " .. DeviceName .. " to:" .. Command .. " " .. Level .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = Command .. " " .. Level}
print(" ==> Set " .. DeviceName .. " to:" .. Command .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = Command}
if dstatus == "Set Level" then
print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs) }
print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " AFTER " .. tostring(TimeSecs) }
return
-- set lamp to 100 % for 5 minutes and than back to its original value
TempSwitchChange("LAMP","Set Level", "100","300")
-- set lamp on for 5 minutes and than back to its original state
TempSwitchChange("Lamp2","On", "","300")
Evelen
thanks jvdz.
where in the script should I put in information?
- jvdz
Have you scrolled all the way down in the code and seen the examples I put in?
Jos
Jos
- G3rard
- Target OS: -
- Domoticz version: No
Thanks for sharing this script, very handyjvdz wrote:I use this function to temporary change a switch to something and then have it return to its previous state:JosCode: Select all
commandArray = {} -- Set lights on for a certain time and then revert back to the original state function TempSwitchChange(DeviceName, Command, Level, TimeSecs) local dstatus = otherdevices[DeviceName] local dvalue = otherdevices_svalues[DeviceName] print("!### TempSwitchChange DeviceName:" ..DeviceName .." Command:" .. Command .." Level:" ..Level .." TimeSecs:" .. TimeSecs) print(" Current status:" ..dstatus .." dvalue:" .. dvalue) if dstatus == nil then -- invalid switch print(" ==> Invalid switchname " .. DeviceName .. " (" .. ScriptName .. ")") elseif (dstatus == Command and dstatus == "Set Level" and dvalue == Level) then -- no change so don't do anything print(" ==> Nothing to change for " .. DeviceName .. " (" .. ScriptName .. ")") elseif (dstatus == Command and dstatus ~= "Set Level") then -- no change so don't do anything print(" ==> Nothing to change for " .. DeviceName .. " (" .. ScriptName .. ")") else -- if Command == "Set Level" then -- Set future status thorugh LUA print(" ==> Set " .. DeviceName .. " to:" .. Command .. " " .. Level .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = Command .. " " .. Level} else print(" ==> Set " .. DeviceName .. " to:" .. Command .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = Command} end if dstatus == "Set Level" then -- Set future status thorugh LUA print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs) } else print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " AFTER " .. tostring(TimeSecs) } end end return end -- set lamp to 100 % for 5 minutes and than back to its original value TempSwitchChange("LAMP","Set Level", "100","300") -- set lamp on for 5 minutes and than back to its original state TempSwitchChange("Lamp2","On", "","300") return commandArray
I only get an error because ScriptName is not defined, so I added
local ScriptName = "TempSwitchChange"Not using Domoticz anymore
