Hi.
Somtimes I want to change the status of a lamp, f.eks set the light to blue 100% dim for 1 sec, then change it back (as a notification, facebook ect)
eks:
- Color is red 24% dim
- facebook notification = set color blue 100% dim for 1sec
- Set Color back to red 24% dim
or:
- light is off
- light off
Is this posible? as easy as possible.
I only use Blockly until now, but maybe LUA must be used here?
turn a light to "Last state"?
- Egregius
- Domoticz version: v2024.7
Re: turn a light to "Last state"?
First store the current value in a variable or other cache system.
Set the new color and then read the variable again to set the old one.
Evelen
- Domoticz version: 2.4538
It sounds logical, but how?
Search for "store variable lua domoticz", i searched for this some time ago and found some examples og storing values with LUA.Evelen wrote:It sounds logical, but how?
- jvdz
- Domoticz version: 4.107
I use this function to temporary change a switch to something and then have it return to its previous state:
Jos
-- Set lights on for a certain time and then revert back to the original state
function TempSwitchChange(DeviceName, Command, Level, TimeSecs)
local dstatus = otherdevices[DeviceName]
local dvalue = otherdevices_svalues[DeviceName]
print("!### TempSwitchChange DeviceName:" ..DeviceName .." Command:" .. Command .." Level:" ..Level .." TimeSecs:" .. TimeSecs)
print(" Current status:" ..dstatus .." dvalue:" .. dvalue)
if dstatus == nil then
-- invalid switch
print(" ==> Invalid switchname " .. DeviceName .. " (" .. ScriptName .. ")")
elseif (dstatus == Command and dstatus == "Set Level" and dvalue == Level) then
-- no change so don't do anything
print(" ==> Nothing to change for " .. DeviceName .. " (" .. ScriptName .. ")")
elseif (dstatus == Command and dstatus ~= "Set Level") then
if Command == "Set Level" then
-- Set future status thorugh LUA
print(" ==> Set " .. DeviceName .. " to:" .. Command .. " " .. Level .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = Command .. " " .. Level}
print(" ==> Set " .. DeviceName .. " to:" .. Command .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = Command}
if dstatus == "Set Level" then
print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs) }
print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")")
commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " AFTER " .. tostring(TimeSecs) }
return
-- set lamp to 100 % for 5 minutes and than back to its original value
TempSwitchChange("LAMP","Set Level", "100","300")
-- set lamp on for 5 minutes and than back to its original state
TempSwitchChange("Lamp2","On", "","300")
Evelen
thanks jvdz.
where in the script should I put in information?
- jvdz
Have you scrolled all the way down in the code and seen the examples I put in?
Jos
Jos
- G3rard
- Target OS: -
- Domoticz version: No
Thanks for sharing this script, very handyjvdz wrote:I use this function to temporary change a switch to something and then have it return to its previous state:JosCode: Select all
commandArray = {} -- Set lights on for a certain time and then revert back to the original state function TempSwitchChange(DeviceName, Command, Level, TimeSecs) local dstatus = otherdevices[DeviceName] local dvalue = otherdevices_svalues[DeviceName] print("!### TempSwitchChange DeviceName:" ..DeviceName .." Command:" .. Command .." Level:" ..Level .." TimeSecs:" .. TimeSecs) print(" Current status:" ..dstatus .." dvalue:" .. dvalue) if dstatus == nil then -- invalid switch print(" ==> Invalid switchname " .. DeviceName .. " (" .. ScriptName .. ")") elseif (dstatus == Command and dstatus == "Set Level" and dvalue == Level) then -- no change so don't do anything print(" ==> Nothing to change for " .. DeviceName .. " (" .. ScriptName .. ")") elseif (dstatus == Command and dstatus ~= "Set Level") then -- no change so don't do anything print(" ==> Nothing to change for " .. DeviceName .. " (" .. ScriptName .. ")") else -- if Command == "Set Level" then -- Set future status thorugh LUA print(" ==> Set " .. DeviceName .. " to:" .. Command .. " " .. Level .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = Command .. " " .. Level} else print(" ==> Set " .. DeviceName .. " to:" .. Command .. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = Command} end if dstatus == "Set Level" then -- Set future status thorugh LUA print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " " .. dvalue .. " AFTER " .. tostring(TimeSecs) } else print(" ==> Set " .. DeviceName .. " to:" .. dstatus .. " AFTER " .. tostring(TimeSecs).. " inx=" .. #commandArray + 1 .. " (" .. ScriptName .. ")") commandArray[#commandArray + 1] = {[DeviceName] = dstatus .. " AFTER " .. tostring(TimeSecs) } end end return end -- set lamp to 100 % for 5 minutes and than back to its original value TempSwitchChange("LAMP","Set Level", "100","300") -- set lamp on for 5 minutes and than back to its original state TempSwitchChange("Lamp2","On", "","300") return commandArray
I only get an error because ScriptName is not defined, so I added
local ScriptName = "TempSwitchChange"Not using Domoticz anymore
