KlikAanKlikUit AWMR-230 pairing
433Mhz opensource Receiver & Transmitter.
vodor
Post by vodor »
Has anybody managed to get the KlickAanKlikUit AWMR-230modules to pair with the rflink?
I followed the same process by manually adding a switch with type AC and pick a unique ID. Press the pair button on the device and press the test button on Domoticz. It sends the command but does not detect the switch.
I also tried the learn switch just to see also without any luck.
Anybody else managed to get these working? A special trick I am missing perhaps?
manjh
Domoticz version: 2025.2
Re: KlikAanKlikUit AWMR-230 pairing
Post by manjh »
Are you sure you selected RFLink in the hardware field of the switch?
Hans
vodor
Post by vodor »
Yip I made sure of that. I will wire up another one tomorrow and see if it behaves the same way.
