Somfy Telis Remotes
SHadley1138
Re: Somfy Telis Remotes
10;Rts;clean
piokuc
Thanks.
But why it not working for me ? What i do wrong ? Why not open and close my somfy if reconized signal ?
And why RC which i send is 0412 but in RFLink save 0413 ?
SHadley1138
I had similar problems, Rflink looked OK, but domoticz just wouldn't work
I think the number has increased as its a rolling code, so it changes each time it's used
piokuc
Is any chance to fix it and help me to start working with Somfy ? For now not working.
Is anybody who start working it with somfy and can help me ?
SHadley1138
I used the dry contacts in the end and bought a cheap relay from eBay
Might have another play today
piokuc
But any user use it as write on forum... any help
Anybody run somfy on RFLink with Domoticz ?
octopuss83
Hello ,
My blind works ok with rflink with the command : 10;RTS;0100F2;0;DOWN; . I wrote to the rflink developper you must create new remote in EEPROM RFlink address , i see that level is reached on the post ... But it s very important to choose a remote address who not begin by 00.... ; address could be 20.... for example .
In My case Domoticz not send command 10;RTS;0100F2;0;DOWN; to rf link I have a message "Error sending switch command, check device/hardware !"
The other switch works very well.
If you need help on rflink i can help you
if you need help on DomoticZ u can help me
Best regards
Best regards
Best Regards
------========= Octopuss =======---------
supermat
Hi,piokuc wrote:HI
I read this manual:
https://matdomotique.wordpress.com/2016 ... -et-somfy/
i send commandand then i press for about 3 secund button on remote to PROG.Code: Select all
10;RTS;0F0F0F;0412;3;PAIR;
On loader show exampleCode: Select all
20;07;OK;
You must press for about 3 second on remote to prog AND THEN send the command to pair
10;RTS;0F0F0F;0412;3;PAIR;The RC is the rolling code, it do +1 for each command send and pairring is a command.
piokuc
Hi i pressed about 3 sec.
But after i prog RFLink then i must also prog Blinds by send command from RFLink ? But after that Remote will stop working ? Now my remote works ok with blinds.
piokuc
Is anybody who can write step by step how configure Somfy with RFLink to working in Domoticz ? Please....
SHadley1138
I've tried loads to get this to work, but just can't get it to work. I can program it into Rflink using the loader, but I just can't get it to work
piokuc
I do all as write in manual:
and i tested without rooling code (correct in manual one day ago) and problem is the same. Blinds run for some seconds (maybee 3 to 5 seconds) and stop. Send command again , run again blinds only for 3-5secund and stop. But command should run blind to close full window. Why working only some secunds ?
I send command:
From remote SMOOVE ORIGIN RTS works ok. When i click button DOWN blinds run and full close my window.
Please help.
I send command:
10;RTS;02FFFF;3;DOWN;Please help.
bananig
Hi piokuc,
did you ever solve your issue?
it is the same for me. i could setup the rflink and can send UP and DOWN commands, but the blinds only run for a few seconds and then stop, instead of completing up/down to the end.
would appreciate your help.
I think that the problem can be related to this:
hoeby
- Domoticz version: V2022.1
I have 2x somfy tilt 50 venetian blind motors.
I tried and googled and tried. But couldn't get it to work propperly. What i did, was connecting a device with espeasy to the pcb (solder). Works without issues. Rf-link is disconnected and dropped in a box.
Maybe not what you would like to hear. Hopefully for you, you can find the answer to it.
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
homeJLB
- Domoticz version: 2024.7
I have a RFX-com-XL and before a RFX-com-E both connected to 9 Somfy blinds. they worked for over 5 years now. But now the board is crashed (tinker board + tinker board OS) and I'm putting everything over on Raspberry Pi4 - 4. I to had some trouble reconnecting the new Domoticz and rfx to the blinds. So I cleared all remote in the RFX and I reset the Blinds with the 3-8-3 method. now all is working again. For RF-link I have no experience
@hoeby; what do you meen by disconnected and dropped in a box.
hoeby
That i don't use rf-link anymore. I only used it for somfy, but it didn't worked perfect on blinds,homeJLB wrote: Saturday 30 October 2021 19:49 @hoeby; what do you meen by disconnected and dropped in a box.
Disconnected it from the pi and put it away
