ESP8266 with 2x1-wire temp sensors
bartpl
Post by bartpl »
I have just tried to connect my ESP8266 whihc has 2 x 1-wire dallas temp sensors connected. ESP has installed ESPEasy scketch which was working fine with thingspeak.
Since I have just installed DOMOTiCZ on Pi3 I wanted to use data from ESP. In ESP Easy I have changed config to:
1. Protocol - DOMOTICZ HTTP
2. IP - IP address of my Pi with DOMOTICZ
3. PORT - 8080 (I haven't changed fresh installation of DOMOTICZ so I assume port 8080 is correct one
4. As a UNIT NR I have used idx of the hardwer in domoticz ( I have created virtual sensor and selected temp sensor) - to be honest I do not know how I can add another sensor)
My ESP seems to connect to DOMOTICZ as I see it in logs BUT, temperature seems not to be updated, shows 0 all the time.
Can you pls help me?
bartpl
Re: ESP8266 with 2x1-wire temp sensors
Post by bartpl »
OK. I solved it... I changed IDX in wrong place of ESPeasy :-)
