Tablet + Domoticz
- Domoticz version: 4.
Tablet + Domoticz
Has anybody installed Domotiz in a Linux Tablet?
I think it would be a good idea to run domotic in such device, don't it?
- Egregius
- Domoticz version: v2024.7
Re: Tablet + Domoticz
Why would that be so good? Tablet mostly go to sleep, but I never had a Linux tablet so could be wrong about that.
And then a USB cable with a hub to connect everything?
You want your Domoticz running after a wifi connection?
I think you're better off buying a RPI and just use the tablet to control it.
Well, but with a tablet you have a enough powerful processor plus a touchscreen, all in one device.
I do it on a chroot debian running on Android.
That rock's well.
Only problème is about USB, rflink was hère but rfxcom not.
Need some tweak to run mydomoathome service to run imperihome.
This a way to get A full system in one pièce.
Tablet is an Acer A1 810.
I plan to repeat the same but on a windows one : Pipo x9s
Domoticz + Sarah voice reconizion, face reconizion, gesture and qrcode, + windows tts + kinect as mic + cam.
That rock's well.
http://domo-attitude.fr
Then don't you use ZWave controller?
- Domoticz version: v3.8975
I really do not understand the point.
Most people run Domoticz on either RPi or an HDD running linux. Some on Windows.
Why would you need to run it on a tablet?
- No access to GPIO
- Dependence on the battery life
- Dependence on the Wifi signal
- How would you hook up Zwave / rfxcom? I have three transceivers connected to My RPi, How do I connect them to a tablet?
You can control Domoticz on RPi with a tablet - that's fine.
- No access to GPIO
Why is neccsary Access to GPIO?
Tablet can be connected to electricity or can use battery, as RPI
Dependence on the Wifi signal? Why?
USB, if you use a hub... but yes, tis can be a problema for people using differents technology.
I see a tablet as a RPI or Cubie plus a touch Screen. This is the reason of the question.
You can still use your rpi as a ser2net server (who share serial USB via lan).
Rpi healt is dépendante to sdcard, rpi is a dev board.
If you plan to made a contrôle screen, a tablet is a good solution, maybe you will prefer the 7" rpi screen ? (This need GPIO !)k
No zwave at home all work with 433 or wifi module.
rip with tablet is working fine.
- Domoticz version: 2.2364
I use my Wetab tablet PC for Domoticz, purely because because it was collecting dust. There is no real advantage in using a tablet, Ican say after a year. After installing Ubuntu I used remote access with SSH.
One could use the tablet wall-mounted for displaying a Frontpage, or the standard Domoticz webpage, but a connected Rfxcom has to mounted alongside it as well. Not acceptable for my wife....
