Usb300 with Eltako fam14 and frs14
bjansen
Post by bjansen »
Hello forum,
Being an absolute newbie I tried to get some Enocean working. However, I fail to control my eltako frs14 from the Domoticz.
(Without the domoticz / usb300 my frs14 is switching fine based on whatever input connected to the eltako rs485 bus).
- I created enocean device in hardware. (seems to work as some devices are listed)
- I did put my fsr14 into learning mode, such that the button pressed at that point would activate the relay.
- I created a manual light/switch with Hardware Enocean and Type Enocean.
- I press the test button when creating the switch/light. I am assuming here this will send a button pressed over the enocean to the fam14. It seems to be the case as the fam14 led is blinking briefly. However, the frs14 doesn't receive it or accept it (it remains in learning mode).
So, what am I doing wrong? Is the fam14 not relaying the message from enocean over the rs485? Or is the domoticz/usb300 not sending the right message?
Thanks a lot for your help.
Bart
