Delete device with Json?
Westcott
Post by Westcott »
Is it possible to delete devices with Json?
Something like -
/json.htm?type=command&param=deletedevice&idx=IDX
This doesn't work, returning an ERR status
Egregius
Domoticz version: v2024.7
Re: Delete device with Json?
Post by Egregius »
Think it should be something like:
http://192.168.0.10:8084/json.htm?type=setused&idx=535&name=test&description=&used=false
That's the url that's called when you edit/remove a device.
Or
http://192.168.0.10:8084/json.htm?type=deletedevice&idx=535
when deleting from the devices view.
Both urls tested and confirmed as working.
Westcott
Post by Westcott »
Hi Egregius,
Thanks for the quick answer!
Yes, your 2nd example works for me, even simpler than I guessed.
Perhaps it should be documented in the Wiki?
I'm going to use it to delete spurious unused devices added by RFX and RFlink.
Egregius
Post by Egregius »
Be carefull...
I would just leave them there or disable new sensors.
