@safi78 do you mind sharing how that's done? I now switch off my entire onkyo receiver with a KAKU switch...Connected my Onkyo receiver through a Python library on the Rasp (<- cool, switching it on and off through LUA)
/paul
sudo apt-get install python-setuptoolsCode: Select all
sudo easy_install onkyo-eiscpCode: Select all
onkyo system-power:onCode: Select all
onkyo system-power:standbyCode: Select all
if (devicechanged['FakeOnkyoSwitch']="Off") then
os.execute('/usr/local/bin/onkyo blablabla)
onkyo --help-commands mainCode: Select all
root@jarvis ~ $ onkyo --help-commands main system-power
Possible values for this command:
standby - sets System Standby
on - sets System On
query - gets the System Power StatusNot only will it give tracebacks due to a timeout while waiting for a response of a switched off receiver, but you will also not be able to put it on again through the network...For the power on command to work while the device is in standby, make sure you turn on the obtusely named Setup -> Hardware -> Network -> Network Control option. Without it, you can only connect to your receiver while it is already turned on.
if (devicechanged['Dummy_onkyo_switch'] == "On") then
os.execute('/usr/local/bin/onkyo system-power:on')
commandArray['Dummy_onkyo_switch'] = on
