I have a Wifi gateway from MiLIght that is controlling a number of RGB zones with RGB ledstrips (not RGBW!). When i define the LimitlessLed hardware in domoticz the controller and RGBW devices are being created. When i do a set mode to RGB, i do not see any additional RGB devices being created as with RGBW or W types.
Am i right that RGB type devices should be created?
LimitlessLed/AppLamp RGB devices not appearing Topic is solved
Re: LimitlessLed/AppLamp RGB devices not appearing
That is correct. Rgb devices are visible as rgbw devices.
OK, i have my devices appearing, defined the IP and Port of the AppLamp RGB controller, but still no luck in getting the strips to react on on/off..
Any ideas, obvious mistakes that ones makes as a first time user of this Applamp integration?
Found it in old post. It just works with Mode = RGBW and change nothing to RGB.
