HDD is running to the max
Derik
- Domoticz version: BETA
Please is there someone that can help me to clean my HDD from my Cubieboard 2..
I see my drive is running to the max..
I try the clean option, that is give some space, only not for long.
My image is:
http://www.armbian.com/cubieboard-2/
Are there some maps that are using a lot of space that i can remove without having problem,,
Or a better solution..
My image is:
- Egregius
- Domoticz version: v2024.7
Re: HDD is running to the max
ssh to it
cd /
du -h -d 1
"du -h -d 1" will show you the actual size of the folders.
Go in to the biggest folders and rerun the command until you find out what's eating your drive.
cd /
du -h -d 1
Derik
mmm you think i am smart .....
Only this screendumps are almost my max ,,
linaro@cubie:/$ sudo du -h -d 1
5.1M ./boot
4.0G ./var
4.0K ./media
13M ./tmp
16K ./lost+found
4.0K ./opt
42M ./home
192K ./run
4.0M ./etc
0 ./dev
5.1M ./bin
4.0K ./mnt
5.5M ./sbin
du: cannot access './proc/12638/task/12638/fd/4': No such file or directory
du: cannot access './proc/12638/task/12638/fdinfo/4': No such file or directory
du: cannot access './proc/12638/fd/4': No such file or directory
du: cannot access './proc/12638/fdinfo/4': No such file or directory
0 ./proc
4.0K ./srv
679M ./usr
32K ./root
396M ./lib
0 ./sys
5.2G .
linaro@cubie:/$
marcelr
- Domoticz version: svn 2470
4.0G ./var
Why is /var so large? Maybe it's time to clean up some garbage there.
grtz,
marcelr
grtz,
marcelr
SweetPants
/var contains all logging. Check there what is using your disk
Verstuurd vanaf mijn HTC Desire 610 met Tapatalk
- Egregius
well,
cd /var
sudo du -h -d 1
/var contains so much more than logging.
Recently I had same issue on one of my RPI's wich had a 2GB card. Appeared that all old kernels where still on the card...
cd /var
sudo du -h -d 1
- gizmocuz
also the tool 'ncdu' is helpfull, it is a graphical 'du' application
Derik
Can i just simple delete the whole map ./var
- jvdz
- Domoticz version: 4.107
Not when you still want to use the system afterwards.Derik wrote:Can i just simple delete the whole map ./var
So have you checked the subdirectories for large files. I would first check /log, /backups and /tmp
Jos
Derik
Just the first big ones?
And here to?
Can i remove the older versions???
The only backup i wil give a lot of money is my Domoticz DB...
When my OS stock, i set a new os on my sd...
- jvdz
Seems you aren't running the logrotate utility that normally would clean and compress logfiles to ensure they don't grow to that size.
EDIT: Looks like it was working till 25 January last year as there are compressed versions of auth.log
Jos
Jos
Derik
Okjvdz wrote:Seems you aren't running the logrotate utility that normally would clean and compress logfiles to ensure they don't grow to that size.
Jos
I did change nothing. [ i think ]
Just flash the sd and run domoticz on it...[ runs 2-3 years ]
Can i remove this log files..? [ in all the years i did not use this stuff ]
And the DPKG.Status old versions?
And the alternative and apt.extend. xx old versions?
- jvdz
Why worry about the few Kb's of the DPKG? The issue seems to be the log files not being cleared.
You can find quite some hits on Google on this question around deleting auth.log, but think you really should fix the logrotate so the system won't fill up again over time.
Jos
Jos
Derik
Hero's....
And proud @ myself...
- Egregius
I would run these commands:
sudo truncate -s 0 *.log -> empty all logfiles without deleting them and thus preserving ownership and permissions.
sudo rm *.gz -> remove all old compressed logfiles. This can also be done in /var/backups
Don't know what those btmp files are occupying 200MB, should google that to see if it's safe to remove/empty them.
Also, try to find out why logrotate doesn't run anymore, then that handles it automatically for you.
In the config files of logrotate you can specify how many .gz files are kept.
Derik
linaro@cubie:~$ cd /var/log
linaro@cubie:/var/log$ sudo truncate -s0 auth.log
linaro@cubie:/var/log$ sudo truncate -s0 syslog
linaro@cubie:/var/log$ sudo truncate -s0 daemon.log
linaro@cubie:/var/log$ sudo truncate -s0 kern.log
linaro@cubie:/var/log$ sudo truncate -s0 btmp.1
linaro@cubie:/var/log$ sudo truncate -s0 message
linaro@cubie:/var/log$ sudo truncate -s0 messages
linaro@cubie:/var/log$ sudo truncate -s0 auth.log.1
linaro@cubie:/var/log$ sudo truncate -s0 debug
linaro@cubie:/var/log$ sudo truncate -s0 messages.1
linaro@cubie:/var/log$ sudo truncate -s0 kern.log.1
linaro@cubie:/var/log$ sudo truncate -s0 syslog.1
linaro@cubie:/var/log$ sudo truncate -s0 lastlog
linaro@cubie:/var/log$ sudo truncate -s0 dpkg.log.1
THANKS ALL!!
xxx
marcelr
Drops as steeply as the exchange rate of the British Pound
grtz,
marcelr
grtz,
marcelr
Derik
marcelr wrote:Drops as steeply as the exchange rate of the British Pound
grtz,
marcelr
My drop is better/;
- Egregius
Seems a nice tool, thanks.gizmocuz wrote:also the tool 'ncdu' is helpfull, it is a graphical 'du' application
But not available on OS X and Synology so I searched some more and came up with these commands:
find biggest folders
perl -e'%h=map{/.\s/;99**(ord$&&7)-$`,$_}`sudo du -h -d 1`;die@h{sort%h}'Code: Select all
perl -e'%h=map{/.\s/;99**(ord$&&7)-$`,$_}`sudo du -h`;die@h{sort%h}'1 level:
sudo du -BM -d 1| sort -nCode: Select all
sudo du -BM | sort -n
