extract 5 minute Toon data from domoticz.db
geoffrey
Post by geoffrey »
I would like to extract my 5 minute P1 E readings from Toon and my hourly P1 G readings from Toon out of the domoticz.db so I can back them up in a detail database.
Not sure which tables to use for this... Any hints?
Or is this also extractable through the JSON i/f? my Toon P1 E sensor id =11, my G sensor id =12...
any help appreciated.
G.
dannybloe
Re: extract 5 minute Toon data from domoticz.db
Post by dannybloe »
You could try dzVents and have it collect 5 minutes worth of samples using a 'historical variable'. Combine this with a script that runs every 5 minutes and you could serialize it to some other system. All in a Lua script. Takes you just a few lines of code. That way you don't need low-level db access.
Something like this:
	active = true, -- set to true to activate this script
		'myToonDevice',
		['timer'] = 'every 5 minutes',
	data = {
		energyReadings = { history = true, maxMinutes = 5 }
	execute = function(domoticz, toon, triggerInfo)
		if (triggerInfo.type == domoticz.EVENT_TYPE_DEVICE) then
			-- toon was updated, add the reading to the data set
			domoticz.data.energyReadings.add(toon.utility) -- holds the current reading
			-- timer event was triggered
			-- so 5 minutes has passed
			-- at this point you can do something with the historical data
			domoticz.data.energyReadings.forEach(function(watt)
				-- collect
			end)
			-- save it somewhere
			-- reset the readings for the next 5 minutes
			domoticz.data.energyReadings.reset();
