I am using 433mhz and Z-Wave at the moment, but I need a few switches that can switch 4 different loads, or even better 6. Is there anything out there? The most I found was a dual-switch.
Thank you
Daniel
Z-Wave switch at least 4 loads?
- Egregius
- Domoticz version: v2024.7
Re: Z-Wave switch at least 4 loads?
Just relay's? Our outlets? Maybe something like the Greenwave Powernode 6? Ideal for switching media stuff.
And otherwise, why not 2 double relays? Or 3?
Oh, what I forgot: I am in Europe.
To clarify: I need to switch 6 different lights, so I need an in-wall relay.
I can always use 3 double relays, that is true.
Thank you
Daniel
Thank you
Daniel
- Egregius
That will be a crowdy place for the wires
I've never seen relays with more than 2. I have several Qubino and Fibaro Double relays installed. If possible I wouldn't install them all 3 in the same box. Could be that the signal reception/send is degraded because of that.
I have 1 room where I needed 4 lights switched with 4 double direction circuits. I installed 2 dimmers on one side and 1 double relau on the other side.
