At this moment i am able to perform a get request but when i build a post request i get a 400 bad request or a 404 error.
What have I done until now:
- Flash ESP8266 with firmware: v0.9.2.2 AT Firmware.bin
- Tested the post request with chrome browser => Result is OK and value is updated.
Is there anny one with experiance to perform a POST from arduino with the ESP8266?
Below my code until now:
#define SSID "****"
#define PASS "****"
#define DEST_HOST "json.htm?type=command¶m=udevice&idx=20&nvalue=0&svalue=5"
#define DEST_IP "192.168.0.15"
#define TIMEOUT 5000 // mS
#define CONTINUE false
#define HALT true
// #define ECHO_COMMANDS // Un-comment to echo AT+ commands to serial monitor
// Print error message and loop stop.
void errorHalt(String msg)
Serial.println(msg);
Serial.println("HALT");
while(true){};
// Read characters from WiFi module and echo to serial until keyword occurs or timeout.
boolean echoFind(String keyword)
byte current_char = 0;
byte keyword_length = keyword.length();
// Fail if the target string has not been sent by deadline.
long deadline = millis() + TIMEOUT;
while(millis() < deadline)
if (Serial2.available())
char ch = Serial2.read();
Serial.write(ch);
if (ch == keyword[current_char])
if (++current_char == keyword_length)
Serial.println();
return true;
return false; // Timed out
// Read and echo all available module output.
// (Used when we're indifferent to "OK" vs. "no change" responses or to get around firmware bugs.)
void echoFlush()
{while(Serial2.available()) Serial.write(Serial2.read());}
// Echo module output until 3 newlines encountered.
// (Used when we're indifferent to "OK" vs. "no change" responses.)
void echoSkip()
echoFind("\n"); // Search for nl at end of command echo
echoFind("\n"); // Search for 2nd nl at end of response.
echoFind("\n"); // Search for 3rd nl at end of blank line.
// Send a command to the module and wait for acknowledgement string
// (or flush module output if no ack specified).
// Echoes all data received to the serial monitor.
boolean echoCommand(String cmd, String ack, boolean halt_on_fail)
Serial2.println(cmd);
#ifdef ECHO_COMMANDS
Serial.print("--"); Serial.println(cmd);
#endif
// If no ack response specified, skip all available module output.
if (ack == "")
echoSkip();
// Otherwise wait for ack.
if (!echoFind(ack)) // timed out waiting for ack string
if (halt_on_fail)
errorHalt(cmd+" failed");// Critical failure halt.
return false; // Let the caller handle it.
return true; // ack blank or ack found
// Connect to the specified wireless network.
boolean connectWiFi()
String cmd = "AT+CWJAP=\""; cmd += SSID; cmd += "\",\""; cmd += PASS; cmd += "\"";
if (echoCommand(cmd, "OK", CONTINUE)) // Join Access Point
Serial.println("Connected to WiFi.");
return true;
Serial.println("Connection to WiFi failed.");
return false;
// ******** SETUP ********
void setup()
Serial.begin(9600); // Communication with PC monitor via USB
Serial2.begin(9600); // Communication with ESP8266 via 5V/3.3V level shifter
Serial2.setTimeout(TIMEOUT);
Serial.println("ESP8266 Demo");
delay(2000);
//echoCommand("AT+RST", "ready", HALT); // Reset & test if the module is ready
Serial.println("Module is ready.");
echoCommand("AT+GMR", "OK", CONTINUE); // Retrieves the firmware ID (version number) of the module.
echoCommand("AT+CWMODE?","OK", CONTINUE);// Get module access mode.
// echoCommand("AT+CWLAP", "OK", CONTINUE); // List available access points - DOESN't WORK FOR ME
echoCommand("AT+CWMODE=1", "", HALT); // Station mode
echoCommand("AT+CIPMUX=1", "", HALT); // Allow multiple connections (we'll only use the first).
//connect to the wifi
boolean connection_established = false;
for(int i=0;i<5;i++)
if(connectWiFi())
connection_established = true;
break;
if (!connection_established) errorHalt("Connection failed");
delay(5000);
//echoCommand("AT+CWSAP=?", "OK", CONTINUE); // Test connection
echoCommand("AT+CIFSR", "", HALT); // Echo IP address. (Firmware bug - should return "OK".)
//echoCommand("AT+CIPMUX=0", "", HALT); // Set single connection mode
// ******** LOOP ********
void loop()
// Establish TCP connection
String cmd = "AT+CIPSTART=0,\"TCP\",\""; cmd += DEST_IP; cmd += "\",8084";
if (!echoCommand(cmd, "OK", CONTINUE)) return;
delay(2000);
// Get connection status
if (!echoCommand("AT+CIPSTATUS", "OK", CONTINUE)) return;
// Build HTTP request.
cmd = "POST / HTTP/1.1\r\nHost: "; cmd += DEST_HOST; cmd += ":8084\r\n\r\n";
// Ready the module to receive raw data
if (!echoCommand("AT+CIPSEND=0,"+String(cmd.length()), ">", CONTINUE))
echoCommand("AT+CIPCLOSE", "", CONTINUE);
Serial.println("Connection timeout.");
return;
// Send the raw HTTP request
echoCommand(cmd, "OK", CONTINUE); // GET
// Loop forever echoing data received from destination server.
while(true)
while (Serial2.available())
errorHalt("ONCE ONLY");
