Telegram snapshot only when not at home
fransiefrans
- Domoticz version: stable
hi,
I want to get snapshots send to telegram when my frontdoor opens and when uservariableor switch nobody home is on.
Since last update there is a possibility to send snapshots in blocky but I think that's only with email notification, not with telegram.
Is it possible to execute a script in blocky?
If not, is there an other solution?
The snapshot.sh script is working only when I execute in putty, somehow not when I put the script in the on-action of a switch. I got it working but when I did a fresh install of domoticz I still didn't manage to get it to work in domoticz. I use script:/// and changed the rights to 755. Any ideas how I could fix this?
- Egregius
- Domoticz version: v2024.7
Re: Telegram snapshot only when not at home
With my php script and telegram bot integration I receive the snapshot of the motion detection always. But they ony make a notification sound when I'm not a sleep.
For that I use 2 virtual switches: 'Away' and 'Sleep'. They control everything in the home.
Once the switches are there it's as simple as:
<?php
if($SAway=='Off') shell_exec('/home/pi/script.sh');
fransiefrans
My Domoticz won't execute any sh script. in Putty the snapshots are send to telegram. When I try the same script with an on action I only see:
im using the following at on action: script:///home/pi/domoticz/scripts/bash/deurbel.sh
any ideas?
Executing script: /home/pi/domoticz/scripts/bash/deurbel.shim using the following at on action: script:///home/pi/domoticz/scripts/bash/deurbel.sh
any ideas?
fransiefrans
I'm still trying to get the scripts working from domoticz without any luck. Has anyone an idea?
Derik
- Domoticz version: BETA
Perhaps use a dummy switch that you switch with ping your phone or a pir..fransiefrans wrote:I'm still trying to get the scripts working from domoticz without any luck. Has anyone an idea?
And when this dummy is off run the script...
Quotum of attachments sorry
fransiefrans
Thanks for your reply.
Is that any different from a doorcontact or dummy switch switched by hand?
Derik
i do not understand php or more like that stuff.
Only switching a dummy give more freedom..
To active a script u can use a dummy with http to:
This how i activate a script:
Please let me see the script..
script:///home/linaro/domoticz/scripts/bash/hue/kachel_1_aanPlease let me see the script..
fransiefrans
Im trying the following script on an dummy:
#!/bin/sh
#SendMsgTo=$1
SendMsgTo=$TelegramChatId
IP="192.168.2.2" # IP address Camera
SnapFile=$TempFileDir"snapshot.jpg"
if ping -c 1 $IP > /dev/null ; then # if IPCAM is online then:
wget -O - http://192.168.2.1:8080/camsnapshot.jpg?idx=1 > $SnapFile
sleep 2
curl -s -X POST "https://api.telegram.org/bot"$TelegramBotToken"/sendPhoto" -F chat_id=$SendMsgTo -F caption="er wordt aangebeld" -F photo="@$SnapFile"
curl --data 'chat_id='$SendMsgTo --data-urlencode 'text=IP-cam niet beschikbaar.' 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
fi-
pj-r
- Domoticz version: V3.8650
I do the same with rtsp camera in LUA.
TakeSnapshot is virtual switch with 5sec off delay defined. Its becouse rtsp snapshot is quite slow..
-- snapshot script
if (devicechanged['TakeSnapshot'] == 'On') then
--os_time = os.date("%d.%m.%y %H:%M:%S")
print('Snapshot!')
os.execute('/usr/bin/avconv -i rtsp://user:[email protected]:554/ch0_0.h264 -frames:v 1 -an -y /home/user/domoticz/snapshots/snapshot.jpg')
print('Done')
-- now we can post the image to telegram
os.execute('/usr/bin/curl -s -X POST "https://api.telegram.org/bot112233445:YOURTOKEN/sendPhoto" -F chat_id=-CHATID -F photo="@/home/user/domoticz/snapshots/snapshot.jpg" &')
return commandArrayLXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
