Problems with the Foscam 9816P.
ConHome
- Domoticz version: V2.3354
Almost distraught. I have the camera FI9816P and get this not working.
With the Firefox browser, it's all good but succeeds through Domoticz
not. I followed the wiki, many URLs tried but to no avail.
Who knows advice? This is what I have.
- gizmocuz
Re: Problems with the Foscam 9816P.
rtsp is not the image url, but for live video
ConHome
The screenshot was just an example. I have many URLs
tried. What is the correct one.
cogliostrio
If you do a search for your camera at ispy you get two urls, of which one is for jpeg http://www.ispyconnect.com/man.aspx?n=foscam
Theres allso a couple of suggestions in the wiki you could try out https://www.domoticz.com/wiki/Camera_Se ... m_FI9805EP
Finding the correct url can sometimes be quite time consuming.
http://IPADDRESS:554/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=[USERNAME]&pwd=[PASSWORD]&Finding the correct url can sometimes be quite time consuming.
ConHome
Tnx for your reaction but I am sorry, also this examples didnt work for me.
Skippiemanz
- Domoticz version: 4.10233
Try leaving the user name and password field empty, and set the credentials in the URL.
Verstuurd vanaf mijn D6503 met Tapatalk
ConHome
I tried that and even though the other suggestions but no luck.
With Firefox direct i have it working.
Maybe it's my configuration, Domoticz on the RPI.
For example (at the URL below)
http://192.168.178.36:88/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=test&pwd=test- HAL9000
Leaving the username and password fields blank worked out for me.
The imgageURL:
http://[YOUR IPADDRESS]/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=[YOUR USERNAME]&pwd=[YOUR PASSWORD&
I replaced the fields between the cascades [] with my own values. (remove the [ and ] chars.!)
The imgageURL:
Dingetje2004
Did you get it to Work the Foscam 9816p? I am facing the same problems, tried everything! Hope someone haa a solution. Thanks ia!
cobra045
- Domoticz version: 3.4834
For me this works
At the ImageURL;
only -----> cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=tablet&pwd=tablet01&
username= tablet
password = tablet01
At the ImageURL;
username= tablet
password = tablet01
Dingetje2004
Thank you 4 ur help, but unfortunately it does not help! makes me crazy its not working, looking 4 an alternative cam instead.
Dingetje2004
Did you set Some special configurations forthe Foscam itself?cobra045 wrote:For me this works
At the ImageURL;
username= tablet
password = tablet01
cobra045
No, for domoticz I just created an operator
