Can't get Mysensors doorbell sketch to be recognized
dboytim
Post by dboytim »
Here's the code I'm using, minorly changed from the "domoticz-ready" code on the doorbell project on the MySensors site. The only changes I made were pin assignments and turning on the repeater mode.
 * The MySensors Arduino library handles the wireless radio link and protocol
 * between your home built sensors/actuators and HA controller of choice.
 * The sensors forms a self healing radio network with optional repeaters. Each
 * repeater and gateway builds a routing tables in EEPROM which keeps track of the
 * network topology allowing messages to be routed to nodes.
 * Created by Henrik Ekblad <[email protected]>
 * Copyright (C) 2013-2015 Sensnology AB
 * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
 * Documentation: http://www.mysensors.org
 * Support Forum: http://forum.mysensors.org
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License
 * version 2 as published by the Free Software Foundation.
 * REVISION HISTORY
 * Version 1.0 - PeteWill
 * DESCRIPTION
 * This sketch is used to control a doorbell ring with a relay as well as send an
 * alert when the buttons is pressed.  Connect the button to ground and digital
 * pin 3.  The relay controlling the doorbell is conntected to pin 4.
 * Watch the How To video here: https://youtu.be/nMIcalwpstc
 * Version 1.1 - ResentedPoet
 * Added gw.send command so that if doorbellDetect variable was active, it would send V_TRIPPED
 * to the motion sensor controlling the doorbell. Necessary for Domoticz compatibility
#include <MySensor.h>
#include <SPI.h>
#include <Bounce2.h>
#define NODE_ID AUTO // or set to AUTO if you want gw to assign a NODE_ID for you.
#define DOORBELL_PIN  A0      // Arduino Digital I/O pin number for the doorbell button
#define RELAY_PIN  4         // Arduino Digital I/O pin number for the relay
#define DOORBELL_CHILD_ID 0  //ID of the doorbell
#define SWITCH_CHILD_ID 1    // Id of the switch that will control doorbell sound
#define RELAY_ON 1
#define RELAY_OFF 0
Bounce debouncer = Bounce();
MySensor gw;
MyMessage switchMsg(SWITCH_CHILD_ID, V_LIGHT);
MyMessage doorbellMsg(DOORBELL_CHILD_ID, V_TRIPPED);
unsigned int doorbellDelay = 1000; // interval at which to keep the doorbell button sensor triggered (milliseconds). This is used to stop people (kids) from pressing it too often
unsigned int ringTime = 400; //How long the doorbell relay is on (in milliseconds)
unsigned long doorbellMillis;  //Used to keep track of the last doorbell button press
unsigned long doorbellTimer;  //Used to keep track of doorbell ring time
byte doorbellPreviousVal;  //Used to keep track of doorbell button pressed state
boolean ringDoorbell;  //Used to initiate the ring doorbell if statement
boolean doorbellSound; //Used to keep track if the doorbell should sound or be silent.  Value recieved from doorbell on/off switch
boolean doorbellOff = true;  //Used to keep track of doorbell ring state
void setup()
  gw.begin(incomingMessage, NODE_ID, true);
  // Send the sketch version information to the gateway and Controller
  gw.sendSketchInfo("Doorbell Monitor", "1.0");
  // Setup the button and activate internal pull-up
  pinMode(DOORBELL_PIN, INPUT_PULLUP);
  // After setting up the button, setup debouncer
  debouncer.attach(DOORBELL_PIN);
  debouncer.interval(5);
  // Register all sensors to gw (they will be created as child devices)
  gw.present(SWITCH_CHILD_ID, S_LIGHT);
  gw.present(DOORBELL_CHILD_ID, S_MOTION);
  // Make sure relays are off when starting up
  digitalWrite(RELAY_PIN, RELAY_OFF);
  // Then set relay pins in output mode
  pinMode(RELAY_PIN, OUTPUT);
  // Set doorbellSound to last known state (using eeprom storage)
  doorbellSound = gw.loadState(SWITCH_CHILD_ID);
void loop()
  gw.process();
    unsigned long currentMillis = millis();
  //Check to see if doorbell button was pushed.
  if (currentMillis - doorbellMillis > doorbellDelay) //used to stop doorbell from being pressed too frequently
    debouncer.update();
    // Read doorbell button value
    byte doorbellDetect = !debouncer.read();//read, then reverse the value so it will send correct trigger state to controller
    if (doorbellDetect != doorbellPreviousVal)
      //Serial.print("doorbellDetect Value: ");
      //Serial.println(doorbellDetect);
      if (doorbellDetect == 1)
        ringDoorbell = true;
        doorbellTimer = currentMillis;
        gw.send(doorbellMsg.set(doorbellDetect?"1":"0"));  // Send tripped value to gw
      doorbellMillis = currentMillis;
      doorbellPreviousVal = doorbellDetect;
  if (ringDoorbell)
    if (doorbellSound)
      if (doorbellOff)
        digitalWrite(RELAY_PIN, RELAY_ON);
        //Serial.println("Doorbell sounded.");
        doorbellOff = false;
        if (currentMillis - doorbellTimer > ringTime)
          ringDoorbell = false;
          //Serial.println("Doorbell off.");
          doorbellOff = true;
  void incomingMessage(const MyMessage & message) {
    // We only expect one type of message from controller. But we better check anyway.
    if (message.isAck()) {
      Serial.println("This is an ack from gateway");
    if (message.type == V_LIGHT) {
      // Change relay state
      doorbellSound = message.getBool();
      // Store state in eeprom
      gw.saveState(SWITCH_CHILD_ID, doorbellSound);
      // Write some debug info
      Serial.print("Incoming change for sensor:");
      Serial.print(message.sensor);
      Serial.print(", New status: ");
      Serial.println(message.getBool());
I've had this doorbell working for months on a Vera system, but now I'm moving everything over to Domoticz on a Pi 3. My domoticz is version v3.4834. Mysensors ethernet gateway is working fine. When I powered up the doorbell, I got an unknown node with sketch "unknown" show up under mysensors. It has 2 children - a repeater with childID 255, and an unknown with childID 0 and a V_Tripped value.
Any idea what I need to do to make it work?
