Most of them are Fibaro Wall Plugs, with the device with Unit 4 added.
Do I use the wrong subdevice?
I only have a couple of different devices, all types had already been included before so it should not be due toPlaagje wrote:You could try to remove those devices and see if they are interfearing with the energy meters.
Sent from my Nexus 5X using Tapatalk
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 102,
"Data" : "On",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"HardwareName" : "Z-Wave",
"HardwareTypeVal" : 21,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00000601",
"Image" : "FibaroWallPlug",
"IsSubDevice" : false,
"LastUpdate" : "2016-06-07 14:05:05",
"Level" : 255,
"LevelInt" : 255,
"MaxDimLevel" : 100,
"Name" : "Kök, Kaffebryggare",
"Notifications" : "false",
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "On",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "17"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "0.0 Watt",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"ID" : "0000604",
"LastUpdate" : "2016-06-16 13:03:19",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "Electric",
"Timers" : "false",
"Type" : "Usage",
"TypeImg" : "current",
"Unit" : 2,
"Used" : 0,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "18"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"HaveTimeout" : true,
"ID" : "0000006",
"LastUpdate" : "2016-06-07 18:05:04",
"PlanID" : "6",
"PlanIDs" : [ 6 ],
"Timers" : "false",
"Type" : "Usage",
"Unit" : 4,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "19"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"ID" : "0000601",
"LastUpdate" : "2016-06-08 20:31:22",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Type" : "Usage",
"Unit" : 2,
"Used" : 0,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "20"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"ID" : "0000006",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Type" : "Usage",
"Unit" : 1,
"Used" : 0,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "21"
2016-06-16 17:41:07.215 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - False
2016-06-16 17:41:07.215 Info, Node003, SwitchBinary::Set - Setting node 3 to Off
2016-06-16 17:41:07.215 Detail, Node003, Queuing (Send) SwitchBinaryCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x25, 0x01, 0x00, 0x25, 0x34, 0xd3
2016-06-16 17:41:07.215 Detail, Node003, Queuing (Send) SwitchBinaryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x25, 0x02, 0x25, 0x35, 0xd3
2016-06-16 17:41:07.216 Info, Node003, Sending (Send) message (Callback ID=0x34, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x25, 0x01, 0x00, 0x25, 0x34, 0xd3
2016-06-16 17:41:07.223 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-06-16 17:41:07.223 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2016-06-16 17:41:07.295 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x34, 0x00, 0x00, 0x07, 0xd8
2016-06-16 17:41:07.295 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x34 received (expected 0x34)
2016-06-16 17:41:07.295 Info, Node003, Request RTT 79 Average Request RTT 61
2016-06-16 17:41:07.295 Detail, Expected callbackId was received
2016-06-16 17:41:07.295 Detail, Expected reply was received
2016-06-16 17:41:07.295 Detail, Message transaction complete
2016-06-16 17:41:07.295 Detail, Node003, Removing current message
2016-06-16 17:41:07.296 Detail,
2016-06-16 17:41:07.296 Info, Node003, Sending (Send) message (Callback ID=0x35, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x25, 0x02, 0x25, 0x35, 0xd3
2016-06-16 17:41:07.303 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-06-16 17:41:07.303 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2016-06-16 17:41:07.320 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x35, 0x00, 0x00, 0x02, 0xdc
2016-06-16 17:41:07.320 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x35 received (expected 0x35)
2016-06-16 17:41:07.320 Info, Node003, Request RTT 24 Average Request RTT 42
2016-06-16 17:41:07.320 Detail, Expected callbackId was received
2016-06-16 17:41:07.331 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x25, 0x03, 0x00, 0xd4
2016-06-16 17:41:07.331 Info, Node003, Response RTT 34 Average Response RTT 46
2016-06-16 17:41:07.331 Info, Node003, Received SwitchBinary report from node 3: level=Off
2016-06-16 17:41:07.331 Detail, Node003, Refreshed Value: old value=true, new value=false, type=bool
2016-06-16 17:41:07.331 Detail, Node003, Changes to this value are not verified
2016-06-16 17:41:07.331 Detail, Node003, Expected reply and command class was received
2016-06-16 17:41:07.331 Detail, Node003, Message transaction complete
2016-06-16 17:41:07.331 Detail, Node003, Removing current message
2016-06-16 17:41:07.331 Detail, Node003, Notification: ValueChanged
2016-06-16 17:41:08.288 Detail, Node003, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x03, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe0
2016-06-16 17:41:08.288 Info, Node003, Received SensorMultiLevel report from node 3, instance 1, [b]Power: value=0.0W[/b]
2016-06-16 17:41:08.288 Detail, Node003, Refreshed Value: [b]old value=1.4, new value=0.0[/b], type=decimal
2016-06-16 17:41:08.288 Detail, Node003, Changes to this value are not verified
2016-06-16 17:41:08.288 Detail, Node003, Notification: ValueChanged
2016-06-16 17:41:11.258 Info, Node003, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2016-06-16 17:41:11.258 Info, Node003, SwitchBinary::Set - Setting node 3 to On
2016-06-16 17:41:11.258 Detail, Node003, Queuing (Send) SwitchBinaryCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x25, 0x01, 0xff, 0x25, 0x36, 0x2e
2016-06-16 17:41:11.258 Detail, Node003, Queuing (Send) SwitchBinaryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x25, 0x02, 0x25, 0x37, 0xd1
2016-06-16 17:41:11.258 Info, Node003, Sending (Send) message (Callback ID=0x36, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=3): 0x01, 0x0a, 0x00, 0x13, 0x03, 0x03, 0x25, 0x01, 0xff, 0x25, 0x36, 0x2e
2016-06-16 17:41:11.265 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-06-16 17:41:11.266 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2016-06-16 17:41:11.283 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x36, 0x00, 0x00, 0x02, 0xdf
2016-06-16 17:41:11.283 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x36 received (expected 0x36)
2016-06-16 17:41:11.283 Info, Node003, Request RTT 24 Average Request RTT 33
2016-06-16 17:41:11.283 Detail, Expected callbackId was received
2016-06-16 17:41:11.283 Detail, Expected reply was received
2016-06-16 17:41:11.283 Detail, Message transaction complete
2016-06-16 17:41:11.283 Detail, Node003, Removing current message
2016-06-16 17:41:11.283 Info, Node003, Sending (Send) message (Callback ID=0x37, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x25, 0x02, 0x25, 0x37, 0xd1
2016-06-16 17:41:11.291 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-06-16 17:41:11.291 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2016-06-16 17:41:11.307 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x37, 0x00, 0x00, 0x02, 0xde
2016-06-16 17:41:11.308 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x37 received (expected 0x37)
2016-06-16 17:41:11.308 Info, Node003, Request RTT 24 Average Request RTT 28
2016-06-16 17:41:11.308 Detail, Expected callbackId was received
2016-06-16 17:41:11.384 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x25, 0x03, 0xff, 0x2b
2016-06-16 17:41:11.384 Info, Node003, Response RTT 100 Average Response RTT 73
2016-06-16 17:41:11.384 Info, Node003, Received SwitchBinary report from node 3: level=On
2016-06-16 17:41:11.384 Detail, Node003, Refreshed Value: old value=false, new value=true, type=bool
2016-06-16 17:41:11.384 Detail, Node003, Changes to this value are not verified
2016-06-16 17:41:11.384 Detail, Node003, Expected reply and command class was received
2016-06-16 17:41:11.384 Detail, Node003, Message transaction complete
2016-06-16 17:41:11.384 Detail, Node003, Removing current message
2016-06-16 17:41:11.385 Detail, Node003, Notification: ValueChanged
2016-06-16 17:41:12.065 Detail, Node003, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x03, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x0d, 0xed
2016-06-16 17:41:12.065 Info, Node003, Received SensorMultiLevel report from node 3, instance 1, [b]Power: value=1.3W[/b]
2016-06-16 17:41:12.065 Detail, Node003, Refreshed Value: old value=0.0, [b]new value=1.3[/b], type=decimal
2016-06-16 17:41:12.065 Detail, Node003, Changes to this value are not verified
2016-06-16 17:41:12.065 Detail, Node003, Notification: ValueChanged
