Zwave network toooooo complicated ? Topic is solved
pascalspits
Post by pascalspits »
doesn't this look tooooooo complicated ?
have I done something wrong ?
do I need to adjust some settings ?
How can I simplify my network ?
I'm worried about it ...
RasPi2 - Aeotec Z-Stick S2 - Fibaro multisensors - Fibaro RGBW dimmers - ETH08 relais boards
Egregius
Domoticz version: v2024.7
Re: Zwave network toooooo complicated ?
Post by Egregius »
What's the problem? What's too complicated?
Looks pretty normal, wait until you have some more devices, then you see nothing anymore.
jvdz
Domoticz version: 4.107
Post by jvdz »
That is what one calls a MESH network :)
Plaagje
Domoticz version: Latest
Post by Plaagje »
Pascal, explain your question?!
Sent from my Nexus 5X using Tapatalk
pascalspits
I thought there were too many connections going on, making the network unstable maybe ?
... that's why I was worried, but apparently this is normal and I shouldn't worry about it ?
jvdz
Post by jvdz »
As said, zwave creates a mesh network with alternative routes to route the information back to the controller. This should make it more stable then with single routes. Maybe a nice read to understand the basics: http://www.vesternet.com/resources/tech ... e-networks
Jos
Egregius
Post by Egregius »
With 49 nodes it look's like this :mrgreen:
StanHD
Post by StanHD »
Spirograph :lol:
Python:- Broadlink RM2, Sonos
mvveelen
Post by mvveelen »
Mespr0n :D :D
@Egregius: this network looks great. Maybe in due time I'll have something similar.
@pascalspits: your networks looks great too. Don't make the mistake to turn polling on, THAT will slow your network down....
Ron
Domoticz version: 2.2284
Post by Ron »
In my configuration the controller doesn't have any connection to other modules, although al seems to work fine.
This has always been the case, what does this mean and did i confiigure something wrong?
Ron
Post by Ron »
Mijn netwerk.
hamish
Post by hamish »
Yeah... I think there's an issue somewhere. Because I have two controllers and 6 nodes. The two controllers are on separate raspberry pi-2's. The first controller (RaBerry) see this...
Screen Shot 2016-06-14 at 21.57.55.png (344.12 KiB) Viewed 7167 times
The second controller (Aeotec G5 USB) sees this...
Screen Shot 2016-06-14 at 21.59.48.png (302.72 KiB) Viewed 7167 times
Given that it's one network. Both graphs SHOULD look the same. But they don't... They also don't quite match the node status. For example the RaZBerry (Node001) graph shows that the network is almost in two parts. With Node005 acting as the relay between one side and the other. Yet the RaZBerry more often than not shows Node005 as DEAD. The second controller (Node004) on the other hand can see Node005 fine...
Very strange... I'm not sure I understand why the graphs and device comms lists should look so different on the same network.
pascalspits
This morning Domoticz asked me to update ... I agreed
This is what I discover this evening ...
suddenly, all by itself !
why ? how ?
juankar
Post by juankar »
You can use Zwave Control Panel to see the topology as a table, perhaps it's easier than this beatiful and coloured picture.
pascalspits
my question is : how can it automatically go from this
to this
only by updating Domoticz ?
NOTHING has changed to the controllers, dimmers, sensors ... to the network itself
how do these connections suddenly appear in the group list and where are all the connections in the graph view ?
behavior in the hous was crazy ... garage licht made heater turning on and all kinds of crazy connections !
I cleaned it up (by removing all "weird" nodes from the groups) and now it looks like this ... everything seems to work, but still the pie-graph doesn't show any connections ... very weird
I'm running Domoticz on RasPi2 with Fibaro RGBW dimmers and Fibaro multi-sensors and an AEOTEC stick
Egregius
Post by Egregius »
The group associations explain the weird behavior.
But why the links are all gone? I really can't say, I assume you waited for the screenshot until all nodes are queried aka blue settings button?
pascalspits
Yep, all nodes are there ... look !
Egregius
Post by Egregius »
And restart or network heal doesn't change anything?
pascalspits
network heal froze/crashed the system, so I rebooted the Pi
after rebooting I check the network information and BOOM !
again it made a bunch of crazy connections all by itself ...
(by the way, this "trap en hall" is a RGBW dimmer from Fibaro)
what am I doing wrong ??
pascalspits
last few weeks again started to notice strange behaviour ... for example : bedroom blinds going up or down when switching on bathroom lights ... ?!
I did a soft reset controller and then these weird Zwave connections appeared again ...
this keeps puzzling me ... where do these crazy connections come from all by theirself ?!
What am I doing wrong here ?
