webcam trouble I6032W-P
Weedzi
Post by Weedzi »
i have this camera and i want it to connect to domoticz... but it doesnt work out of the box at least.
Im not a techy and i dont know if this camera is supported, its not in the list.
its a I6032W-P from revotech https://www.amazon.ca/Revotech%C2%AE-I6 ... 236&sr=1-3
it works from the menu provided from ip but i want to add it to domoticz.
I addded it with add camera and filled in all the settings but doesnt work...
What makes a camera supported and is it possible to add my camera?
pepijn
Re: webcam trouble I6032W-P
Post by pepijn »
Can you post 'your settings'. I don't think this camera supports snapshot URLs but only RTSP streams.
Weedzi
Post by Weedzi »
IP Type:
IP Address:
192.168.1.136
Subnet Mask:
255.255.255.0
Gateway:
192.168.1.1
DNS Type:
Primary DNS:
192.168.1.1
Second DNS:
8.8.8.8
HTTP:
Port :
80
(80 or 1024~32767)
RTSP:
Port:
554
(554 or 1024~32767)
Onvif:
Port:
1018
(1018 or 1024~32767,must reboot)
these settings ? or the settings in domoticz.... in the settings it has a snapshot function...
it should support these protocols Support protocol: HTTP, TCP/IP, ICMP.RTSP, RTP, UDP, RTCP, SMTP, DHCP, DNS, PPPoE, NTP
in image url its just image.jpg.... so that probably something i need to change but to what ? :P
pepijn
Post by pepijn »
You could check if one of the options on this website will work https://www.ispyconnect.com/man.aspx?n=Revotech
I think the snapshot feature in the GUI indicates automatic image uploads.
Weedzi
Post by Weedzi »
yeah i tried those options but the didnt give a working answer....
Lookslike the camera is not supported....
Is there a list of webcams that is supported , and i mean besides the foscams....
are there foscams aftermarket cams that work as wel?
