Nest - HeatingOn switch does not work (Error sending switch command)
Meza
Post by Meza »
I'm new to domoticz, and just got it up and running on my RaspberryPi2.
I've added my nest, and am able to get and set the setpoint and Away status without problem.
However, I cannot use the HeatingOn switch to control the heating on or off.
When I click the switch in domoticz an error pops up:
Error sending switch command, check device/hardware !
and the nest and the switch do nothing.
I've tried removing and re-adding the switch in domoticz with no avail.
Anyone got any ideas?
Thanks,
Meirion
Lasermi
Re: Nest - HeatingOn switch does not work (Error sending switch command)
Post by Lasermi »
Hi!
I have the same issue and I'm pretty sure this worked before. I hadn't played around with the nest since I haven't turned the heating on for a while.
How did you solve the issue?
Meza
Post by Meza »
I haven't solved it yet, am still hoping someone can help out with a solution!
Sent from my PLK-L01 using Tapatalk
Dlanor
Post by Dlanor »
isn't it switch that shows 'status'? Is heating ON or OFF?
*update*
see this older topic. It seams to be the same.
Domoticz| Zigbee | SONOFF
dpui7736
Domoticz version: 4.9700
Post by dpui7736 »
Meza wrote:I haven't solved it yet, am still hoping someone can help out with a solution!
Hi, I have the same problem. Do you solved it?
Meza
Post by Meza »
No I haven't tried anything since then. Not much interest in the heating system in the summer - no demand!
gizmocuz
Post by gizmocuz »
its a status switch... you can not 'set' it
Lasermi
Post by Lasermi »
Hello all,
I tried removing the Nest and Ni joy...
Gizmocuz, I'm pretty sure this worked previously and I'm also sure it works on other applications.
As Meza said, it's still summer, but as winter comes I'll want to enable and disable the heating remotely or through my scripts... Any idea is appreciated!!
Enviado desde mi D6603 mediante Tapatalk
dpui7736
Post by dpui7736 »
gizmocuz wrote:its a status switch... you can not 'set' it
Sorry, I think that it's not true, In my case this switch don't reflect the real state of Nest.
dpui7736
Post by dpui7736 »
Meza wrote:No I haven't tried anything since then. Not much interest in the heating system in the summer - no demand!
Thank you, I think taht probably Nest change something in the API and this switch is send an incorrect order.
