When i send a "/json.htm?type=command¶m=switchlight&idx=${addr}&switchcmd=On" from my app to Domoticz it now gets executed twice, i have put a trace on the app and indeed only one command is send, the first log entry in Domoticz log is inserted by the app as well. What follows is two switch commands, and also two events are being send back to the app (which i indeed see and are getting processed).
This started happening a couple of weeks ago, so it might be introduced with the latest stable for Raspberry Pi. Have upgraded with latest beta but no luck.
Any clue what could be wrong? very annoying as it stops my blinds from closing completely as a second on command is issued it will stop.
Log
2016-05-26 21:10:06.267 SmartThings On for 25
2016-05-26 21:10:06.287 User: Admin initiated a switch command
2016-05-26 21:10:07.796 Notification sent (http) => Success
2016-05-26 21:10:06.288 (RFXCOM) Lighting 2 (Blind Ismay Balkon)
2016-05-26 21:10:07.802 User: Admin initiated a switch command
2016-05-26 21:10:08.958 Notification sent (http) => Success
2016-05-26 21:10:07.804 (RFXCOM) Lighting 2 (Blind Ismay Balkon)
command from other app via JSON executed twice in Domoticz??
- Egregius
- Domoticz version: v2024.7
Re: command from other app via JSON executed twice in Domoticz??
Are you sure there isn't a script or anything that does this?
I only use the json command, even more, the domoticz web interface uses them. Never seen a double line in the logfile.
cherowley
I have this double event when sending a json command via http to a virtual set point...
