ahmedadelhosni wrote:
At last I am happy to solve the problem
Thanks to your help, I found that it breakss in mdah.js in line 2193 due to error in handling the data variable.
for(var i = 0; i < data.result.length; i++)
data.result.length return : Cannot read property 'length' of undefined
I just did someworkarounds and now the mobile application is working.
Can you give me more information where this breaks (I added many lines recently so it is not relevant without your version
Just recently, i've been missing some switches on imperihome.
They are 2 z-wave ones and a lightwave switch.
Also, never seen them in Imperihome, but i have some doorbells i would like to be added too.
What details do you require to assist with that?
Also, with regards to the Evohome implementation we worked on a couple of months back, it never really worked, but couldnt do much about it as Domoticz is improving it evohome implementation. We could still work on that if you like?
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
@stuiow can you send me the /json.htm?type=devices&filter=utility&order=Name for those devices ?
For Evohome this is complicated as there is no match for all, you should see the main evohome device but the two others no for some features do not exist in Imperihome, I opened a ticket on that.
Where you could help would be to define what you expect to do on the IH so I match at the best. e.g. there is no time management for forced mode in IH, having several behavior would mean a multi switch or several switches... does it makes sense ?
Zone
Temp / SetPoint
=> 1 device for Temp
=> 1 device for Thermostat management
Hot Water
=> 1 device for On/Off
Main
MultiSwitch to chose between:
Normal/Eco/Away/Day off/Custom/Heating off
All what you have said is perfect, makes sense re: Evohome switches.
With regards to the link you want, I've loaded that up and had a look over it, but the devices don't appear on there.
I will need to look into that.
I can get them listed via this url, will that be OK? /json.htm?type=command¶m=getlightswitches
should tell you the status. I've not checked where is the pidPath yet.
Thanks - ill take a look at this
hmmm... strange... list does not bring nothing... will evaluate pm2
Thanks - strangely the gateway has stopped working since I posted - no /var/log directory not sure what changed. Anyway I recreated directory and log file and restarted. I guess I might need to add a bash script to recreate on restart as this is a tmpfs
Does the domoticz camera work in Imperihome?
I followed the instructions on the Github page and did a fresh install of MDAH.
Every sensor/switch/etc is loaded correctly into Imperihome, even our camera.
But when I want to add the camerawidget to my dashboard I only can select the Static Camera Widget?
After I exit Edit mode and I press the camerawidget nothing happens???
Am I doing something wrong, or is the domoticz camera not working in Imperihome?
Patrick wrote:Hi
The camera support I push to Imperihome is the one I get from Domoticz. Use this only if you have a PiCam you cannot use by any other mean.
If you have an evolved camera, Imperihome has an extended support for Cameras, I suggest you use this one.
{"devices":[{"id":"S00","name":"Unable to connect to Domoticz","type":"DevGenericSensor","room":"Utility","params":[{"key":"Value","value":"http://127.0.0.1:8080/json.htm"}]},{"id":"S01","name":"Please add this gateway in Setup/settings/Local Networks","type":"DevGenericSensor","room":"Utility"}]}
jumbotroll wrote:
MyDomoAtHome 0.1.38 and
New version found v0.1.39
yes, this is when people ask me for an automated update package method... What should I do to have those packages automatically included in synology third parties tools ?
On synology, I think the best solution is to have a SPK server like I have for domoticz packages like this : http://www.jadahl.com/domoticz_beta_6/
When you update with a higher version number you will have a message from synology package center that there is an update.
epierre wrote:@jumbotroll some people would find it simpler to have both on the same website, so yours would that be possible ?
Thanks,
Of course it is possible , just to speak out when there are updates, so I can put it on my spk server also.
Then I put the available updates on both DSM 5.2 and DSM 6.0 SPK server.
Is it tested on DSM 5.2 ?
I can put it on a ftp server if you like/can to simplify this, or just send you a link to a new version ?
I have only one syno which is now in 6.0 for I follow the editor policy of updates, so I can't test in 5.2 sorry.
Patrick wrote:Hi
Thanks, I'm using the Imperihome camera system now. Works perfect.
