Greenwave Powernode Total usage
Krent
Post by Krent »
I have Domoticz installed on my synology and added my Smart Meter P1 for electricity and gas. That works fine.
Now I also installed a Greenwave Powernode and got it working as well.
My question is about the graphs. With my P1 Smart Meter I can see the total usage of one day, but with the Greenwave Powernode I only see the minimum and maximum per day. Also, the week overview is not shown.
Is it possible to make the powernode calculate the total usage instead of only the minimum and maximum usage?
Also, is it possible to show this total in the dashboard as well?
Any help is highly appreciated...
Plantje
Re: Greenwave Powernode Total usage
Post by Plantje »
For the Wh (rather than only the W) to be displayed sometimes you just have to wait a while. In my case it also helped to completely restart my machine running Domoticz. Remember to go back to the devices and add the device with subtype kWh
Krent
Post by Krent »
Thanks for the answer. I do not see a device with the subtype kWh. I have seen it before, but I installed everything again and now I don't see it anymore... Below the items I see. You can see that I have usage twice, but no kwh...
Plantje
Post by Plantje »
That's really strange...
I think over time the one with ID 12 will display kWh.
I have a similar set of entries for one of my power nodes:
With kWh.PNG (8.12 KiB) Viewed 1231 times
However, I have added two new power nodes and they don't show up with the kWh item either:
Without kWh.PNG (5.72 KiB) Viewed 1231 times
In general if you don't see kWh patience and a reboot of the Domoticz system is a good practice. But I am in doubt if perhaps the NS112-F that I have added now just don't support kWh
