Lua Script tu update a device with json url -help
Mazzokun
Post by Mazzokun »
Hi, I'm writing a lua script to update a instant WATT counter but I doesn't work.. I think that there is a mistake in json url :cry:
if devicechanged['Luci Cancellino'] == 'On'    then  cancellin = 50 else  cancellin = 0 end
if devicechanged['Facciata'] == 'On'           then  facciata = 21  else  facciata = 0 end
if devicechanged['Cupola Esterno'] == 'On'     then  dome = 8       else  dome = 0 end
if devicechanged['Corridoio'] == 'On'          then  hall = 10      else  hall = 0 end
if devicechanged['Cupola Xmas'] == 'On'        then  cupXmas = 500  else  cupXmas = 0 end
if devicechanged['Cancellino Xmas'] == 'On'    then  canXmas = 400  else  canXmas = 0 end
if devicechanged['Lampada Sala'] == 'On'       then  sala = 10      else  sala = 0 end
if devicechanged['Faro dietro'] == 'On'        then  farodie = 35   else  farodie = 0 end
if devicechanged['Faro davanti'] == 'On'       then  farodav = 40   else  farodav = 0 end
if devicechanged['Lanterna facciata'] == 'On'  then  lantfac = 16   else  lantfac = 0 end
if devicechanged['Lanterna nonna'] == 'On'     then  lantnon = 25   else  lantnon = 0 end
if devicechanged['Accento ingresso'] == 'On'   then  accing = 8     else  accing = 0 end
if devicechanged['Lampione'] == 'On'           then  lampion = 23   else  lampion = 0 end
if devicechanged['Presa Volante'] == 'On'      then  presvol = 300  else  presvol = 0 end
if devicechanged['Luce Garage'] == 'On'        then  lucgar = 4     else  lucgar = 0 end
watt= cancellin+facciata+dome+hall+cupXmas+canXmas+sala+farodie+farodav+lantfac+lantnon+accing+lampion+presvol+lucgar
os.execute("curl 'http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=45&nvalue=0&svalue={.watt}' " )
Could you help me? :P
simonrg
Domoticz version: 3.8807
Re: Lua Script tu update a device with json url -help
Post by simonrg »
Mazzokun wrote:Hi, I'm writing a lua script to update a instant WATT counter but I doesn't work.. I think that there is a mistake in json url :cry:
It looks like your quotes in the os.execute are not correct as your variable watt will not be seen as you have placed the quotes.
command ="curl 'http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=45&nvalue=0&svalue="..watt.." ' "
print(command)
os.execute(command)
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Westcott
Post by Westcott »
Why use Json?
Can't you just use an UpdateDevice?
papoo
Domoticz version: 4.10
Post by papoo »
os.execute('curl "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=45&nvalue=0&svalue='..watt' " ')
or
os.execute('curl "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=45&nvalue=0&svalue='..tostring(watt)' " ')
Mazzokun
Post by Mazzokun »
First of all, thank you all; ;)
soFor
print(command)
os.execute(command)
gives me this log and the counter doesn't upload (is red):
2016-05-20 22:09:50.901 EventSystem: reset all events...
2016-05-20 22:09:51.054 Hardware Monitor: Fetching data (System sensors)
2016-05-20 22:09:51.093 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=0 '
2016-05-20 22:10:00.873 EventSystem: Event triggered: script_time_notte_1
2016-05-20 22:10:01.137 Activating Scene/Group: [Luci Notturne Esterno]
2016-05-20 22:10:01.138 Activating Scene/Group Device: Luce Garage (On)
2016-05-20 22:10:01.148 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=4 '
2016-05-20 22:10:01.139 (KmTronic) Lighting 2 (Luce Garage)
2016-05-20 22:10:01.262 Activating Scene/Group Device: Lampione (On)
2016-05-20 22:10:01.268 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=23 '
2016-05-20 22:10:01.262 (KmTronic) Lighting 2 (Lampione)
2016-05-20 22:10:01.353 Activating Scene/Group Device: Lanterna Ingresso (On)
2016-05-20 22:10:01.358 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=0 '
2016-05-20 22:10:01.353 (KmTronic) Lighting 2 (Lanterna Ingresso)
2016-05-20 22:10:01.444 Activating Scene/Group Device: Lanterna Nonna (On)
2016-05-20 22:10:01.449 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=0 '
2016-05-20 22:10:01.444 (KmTronic) Lighting 2 (Lanterna Nonna)
2016-05-20 22:10:01.534 Activating Scene/Group Device: Faro Garage (On)
2016-05-20 22:10:01.540 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=0 '
2016-05-20 22:10:01.535 (KmTronic) Lighting 2 (Faro Garage)
2016-05-20 22:10:01.624 Activating Scene/Group Device: Faro Retro (On)
2016-05-20 22:10:01.630 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=0 '
2016-05-20 22:10:01.625 (KmTronic) Lighting 2 (Faro Retro)
2016-05-20 22:10:01.716 Activating Scene/Group Device: Accento Ingresso (On)
2016-05-20 22:10:01.723 LUA: curl 'http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=45&nvalue=0&svalue=0 '
2016-05-20 22:10:01.717 (KmTronic) Lighting 2 (Accento Ingresso)
For
error in log
Error: EventSystem: in script_device_watt: [string "commandArray = {}..."]:20: attempt to call global 'curl' (a nil value)
@Westcott I tried before, but I'not able to use UpdateDevice; could you give me the right comand please?
papoo
Post by papoo »
commandArray[1] = {['UpdateDevice'] = "45|0|" .. watt}
Mazzokun
Post by Mazzokun »
now the counter isn't red but it still has 0 value :shock: obvious I turned on some switch :lol:
where's the mistake? :cry:
papoo
Post by papoo »
Update device/sensor values using commandArray['UpdateDevice']='idx|nValue|sValue'
try
print(watt)
to know the watt value
and try
commandArray[1] = {['UpdateDevice'] = "45|0|100"}
to set at 100 manually the sValue
Mazzokun
Post by Mazzokun »
Seems that it doesn't like watt= a+b+c+d+e... etc :?
2016-05-20 23:10:24.242 EventSystem: reset all events...
2016-05-20 23:10:52.739 Hardware Monitor: Fetching data (System sensors)
2016-05-20 23:10:52.775 LUA: 0
2016-05-20 23:10:52.776 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:10:59.379 User: Davide initiated a switch command
2016-05-20 23:10:59.394 LUA: 10
2016-05-20 23:10:59.395 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:10:59.380 (KmTronic) Lighting 2 (Corridoio)
2016-05-20 23:11:00.032 EventSystem: Event triggered: script_time_notte_1
2016-05-20 23:11:00.077 Activating Scene/Group: [Luci Notturne Esterno]
2016-05-20 23:11:00.078 Activating Scene/Group Device: Luce Garage (On)
2016-05-20 23:11:00.088 LUA: 4
2016-05-20 23:11:00.089 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:00.078 (KmTronic) Lighting 2 (Luce Garage)
2016-05-20 23:11:00.142 Activating Scene/Group Device: Lampione (On)
2016-05-20 23:11:00.165 LUA: 23
2016-05-20 23:11:00.166 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:00.153 (KmTronic) Lighting 2 (Lampione)
2016-05-20 23:11:00.218 Activating Scene/Group Device: Lanterna Ingresso (On)
2016-05-20 23:11:00.239 LUA: 0
2016-05-20 23:11:00.240 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:00.229 (KmTronic) Lighting 2 (Lanterna Ingresso)
2016-05-20 23:11:00.292 Activating Scene/Group Device: Lanterna Nonna (On)
2016-05-20 23:11:00.314 LUA: 0
2016-05-20 23:11:00.315 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:00.304 (KmTronic) Lighting 2 (Lanterna Nonna)
2016-05-20 23:11:00.367 Activating Scene/Group Device: Faro Garage (On)
2016-05-20 23:11:00.392 LUA: 0
2016-05-20 23:11:00.393 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:00.379 (KmTronic) Lighting 2 (Faro Garage)
2016-05-20 23:11:00.445 Activating Scene/Group Device: Faro Retro (On)
2016-05-20 23:11:00.465 LUA: 0
2016-05-20 23:11:00.466 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:00.454 (KmTronic) Lighting 2 (Faro Retro)
2016-05-20 23:11:00.518 Activating Scene/Group Device: Accento Ingresso (On)
2016-05-20 23:11:00.542 LUA: 0
2016-05-20 23:11:00.543 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:00.530 (KmTronic) Lighting 2 (Accento Ingresso)
2016-05-20 23:11:22.772 Hardware Monitor: Fetching data (System sensors)
2016-05-20 23:11:22.808 LUA: 0
2016-05-20 23:11:22.809 EventSystem: Script event triggered: script_device_watt
2016-05-20 23:11:50.845 Error: Webserver: File '/styles/elemental/images/bg-track.png': No such file or directory (2)
2016-05-20 23:11:52.805 Hardware Monitor: Fetching data (System sensors)
2016-05-20 23:11:52.840 LUA: 0
2016-05-20 23:11:52.841 EventSystem: Script event triggered: script_device_watt
papoo
Post by papoo »
and when you set at 100 manually the sValue ?
Mazzokun
Post by Mazzokun »
yes, if I put
works :roll:
papoo
Post by papoo »
commandArray[1] = {['UpdateDevice'] = "45|0|" .. tostring(watt)}
Mazzokun
Post by Mazzokun »
there are no errors in the log, 0 to the counter.. I think the script does not properly perform the sum of watts :?
simonrg
Post by simonrg »
When the script is called only one device will have changed so you can simplify your script by using elseif and just set watt directly.
watt = 0
if devicechanged['Luci Cancellino'] == 'On'    then  watt = 50
elseif devicechanged['Facciata'] == 'On'           then  watt = 21
elseif devicechanged['Cupola Esterno'] == 'On'     then  watt = 8
elseif devicechanged['Corridoio'] == 'On'          then  watt = 10
elseif devicechanged['Cupola Xmas'] == 'On'        then  watt = 500
elseif devicechanged['Cancellino Xmas'] == 'On'    then  watt = 400
elseif devicechanged['Lampada Sala'] == 'On'       then  watt = 10
elseif devicechanged['Faro dietro'] == 'On'        then  watt = 35
elseif devicechanged['Faro davanti'] == 'On'       then  watt = 40
elseif devicechanged['Lanterna facciata'] == 'On'  then  watt = 16
elseif devicechanged['Lanterna nonna'] == 'On'     then  watt = 25
elseif devicechanged['Accento ingresso'] == 'On'   then  watt = 8
elseif devicechanged['Lampione'] == 'On'           then  watt = 23
elseif devicechanged['Presa Volante'] == 'On'      then  watt = 300
elseif devicechanged['Luce Garage'] == 'On'        then  watt = 4
commandArray['UpdateDevice'] = "45|0|" .. tostring(watt)
simonrg
Post by simonrg »
Thinking about suspect this is not what you want, you are looking to sum the energy of each device to get total energy being used.
To make a sum you are going to need to store the sum as a user variable, then add to this each time a device is switched on and subtract from it each time a device is switched off.
Mazzokun
Post by Mazzokun »
@simonrg Exactly! :)
How can I do this?
Thank's
simonrg
Post by simonrg »
Mazzokun wrote:@simonrg Exactly! :)
How can I do this?
Thank's
The other way to do it is to test the devices each time any device changes or once a minute, which may be simpler.
Probably best to have this as time script rather than a device script, then it will only update every minute, rather every time anything changes.
-- script_device_power_frequent.lua - a device type for the lua script will do the sum every time any device changes
-- script_time_power_every_minute.lua - a time type for the lua script will do the sum only every minute
watt = 0
if otherdevices['Luci Cancellino'] == 'On'    then  watt = watt +  50 end
if otherdevices['Facciata'] == 'On'           then  watt = watt +  21 end
if otherdevices['Cupola Esterno'] == 'On'     then  watt = watt +  8 end
if otherdevices['Corridoio'] == 'On'          then  watt = watt +  10 end
if otherdevices['Cupola Xmas'] == 'On'        then  watt = watt +  500 end
if otherdevices['Cancellino Xmas'] == 'On'    then  watt = watt +  400 end
if otherdevices['Lampada Sala'] == 'On'       then  watt = watt +  10 end
if otherdevices['Faro dietro'] == 'On'        then  watt = watt +  35 end
if otherdevices['Faro davanti'] == 'On'       then  watt = watt +  40 end
if otherdevices['Lanterna facciata'] == 'On'  then  watt = watt +  16 end
if otherdevices['Lanterna nonna'] == 'On'     then  watt = watt +  25 end
if otherdevices['Accento ingresso'] == 'On'   then  watt = watt +  8 end
if otherdevices['Lampione'] == 'On'           then  watt = watt +  23 end
if otherdevices['Presa Volante'] == 'On'      then  watt = watt +  300 end
if otherdevices['Luce Garage'] == 'On'        then  watt = watt +  4 end
EDIT - corrected watt = watt to watt = 0
Mazzokun
Post by Mazzokun »
Doesn't work :( Log:
2016-05-21 13:28:15.686 User: Davide initiated a switch command
2016-05-21 13:28:15.694 Error: EventSystem: in script_device_powerfrequent: [string "-- script_device_power_frequent.lua - a devic..."]:10: attempt to perform arithmetic on global 'watt' (a nil value)
2016-05-21 13:28:15.686 (KmTronic) Lighting 2 (Corridoio)
2016-05-21 13:28:22.523 Error: EventSystem: in script_device_powerfrequent: [string "-- script_device_power_frequent.lua - a devic..."]:10: attempt to perform arithmetic on global 'watt' (a nil value)
Mazzokun
Post by Mazzokun »
THIS SCRIPT WORKS :P :P :P :idea: :idea: :idea: :idea: :idea:
if otherdevices['Luci Cancellino'] == 'On'    then  watt1 = 50    else watt1 = 0 end
if otherdevices['Facciata'] == 'On'           then  watt2 = 21    else watt2 = 0 end
if otherdevices['Cupola Esterno'] == 'On'     then  watt3 = 8     else watt3 = 0 end
if otherdevices['Corridoio'] == 'On'          then  watt4 = 10    else watt4 = 0 end
if otherdevices['Cupola Xmas'] == 'On'        then  watt5 = 500   else watt5 = 0 end
if otherdevices['Cancellino Xmas'] == 'On'    then  watt6 = 400   else watt6 = 0 end
if otherdevices['Lampada Sala'] == 'On'       then  watt7 = 10    else watt7 = 0 end
if otherdevices['Faro Retro'] == 'On'         then  watt8 = 35    else watt8 = 0 end
if otherdevices['Faro Garage'] == 'On'        then  watt9 = 40    else watt9 = 0 end
if otherdevices['Lanterna Ingresso'] == 'On'  then  watt10 = 16   else watt10 = 0 end
if otherdevices['Lanterna Nonna'] == 'On'     then  watt11 = 25   else watt11 = 0 end
if otherdevices['Accento Ingresso'] == 'On'   then  watt12 = 8    else watt12 = 0 end
if otherdevices['Lampione'] == 'On'           then  watt13 = 23   else watt13 = 0 end
if otherdevices['Presa Volante'] == 'On'      then  watt14 = 300  else watt14 = 0 end
if otherdevices['Luce Garage'] == 'On'        then  watt15 = 4    else watt15 = 0 end
watt = 0+watt1+watt2+watt3+watt4+watt5+watt6+watt7+watt8+watt9+watt10+watt11+watt12+watt13+watt14+watt15
commandArray['UpdateDevice'] = "27|0|" .. tostring(watt)
THANK YOU ALL FOR SUPPORT :mrgreen:
simonrg
Post by simonrg »
Glad it all works now.
Mazzokun wrote:Doesn't work :( Log:
The error messages are quite helpful to pick up small errors.
What it is telling you is that on line 10 of script_device_power_frequent.lua there is a variable called watt which hasn't got a value.
Line 10 is watt = watt, if you look further up the script then you can see that watt hasn't been set before, hence watt has no value at this point, also watt = watt doesn't look right.
So line 10 should be watt = 0, this sets watt prior to doing the summing further on, hence watt is not used before its value is set.
